Is there a video request topic for Will we can post to? I know he's said before that he really only makes videos when the community is interested in something. I know he'd do a very well and in-depth demonstration of its uses and pitfalls is the main reason I ask.
My main draw on whether or not I would start saving up to purchase the EG4 18KPV Hybrid is on use of the Smart Load feature on page 55 of the manual: https://eg4electronics.com/backend/wp-content/uploads/2023/04/EG4-18KPV-12LV-Manual-1.4.4.pdf
I'd be interested in basically pre-cooling/heating a room with a mini split when SoC is high and there's a significant PV input.
My main worries are:
* Cloud impact to this load? It has this mention below (in italics). My worry is that if clouds move in and out frequently then you'd often be going from >1000W down to sub 1000W frequently - a Mini-split connected to this output could be flipped on/off too frequently and impact the electronics?
"When the PV power exceeds 1000W, andthe battery system SOC gets to 90%, theSmart Load Port (GEN) will automaticallyswitch on to power the connected load.When the battery reaches SOC<85% orPV power<1000W, the Smart Load Portautomatically switches off."
* The manual doesn't specify that this would be an inverted AC load, and what voltage it would use? Can it be set to 120V only or 240V?
Thanks!
Thanks!
