Well, that’s over 10% over the rated. I’d let others chime in if that’s excessive or notSo should I say to heck with the Over wattage concern (5500w vs 10s=6200w on paper in the nonexistent perfect world), and go full on 10s?
What about early morning when panels first see light but aren't making power? How about when your batteries are full and loads are minimal?OK, not trying to be a wize guy here... but VOC, as I understand it is the rating when the circuit is disconnected., meaning you won't be producing any power or at least consuming any power since you've removed the load.
Below 420VOC, look at the mppt range.So I interpret that as long as only the VOC # is above the 420 you recommend, then that should not be limiting my production. What I don't know of is how the real world translates from paper. I suspect voltage drop and connectors and such each are going to rob things, plus clouds and dust on the panel and any other sort of thing is going to mean I'll never see close to the paper numbers anyway.
You could with the panels you mentioned above but I'd go 5s2p before I went full on 10s. Or follow Hedges good advice and orient strings different directions.So should I say to heck with the Over wattage concern (5500w vs 10s=6200w on paper in the nonexistent perfect world), and go full on 10s?
Some will argue the point that you have peak SCC output over a longer time frame by overpaneling.So should I say to heck with the Over wattage concern (5500w vs 10s=6200w on paper in the nonexistent perfect world), and go full on 10s?
I hadn't looked at it that way. Sorry again for my newbness. Appreciate ya'll tolerating my questions (it's how I learn, before I make the more costlier mistakes and learn the hard way).What about early morning when panels first see light but aren't making power? How about when your batteries are full and loads are minimal?
Lol. Sometimes I need to hear something a few times before I see the vision. Haha. Not trying to ignore ya, but still trying to put it all together.Maybe if I say it long enough it just might cause that lightbulb to go off in your head.
Parallel doesn't require diodes either. Up to two strings parallel, no fuses/breakers required.
Series only requires the built-in bypass diodes.
This is not complicated. On the panel side, the only thing that matters is not to exceed the VOC of the input of the MPPT. Period. You should have a breaker on the feed line that matches the max current of the MPPT. Your MPPT should never draw more than it's rated current, if it does then it is bad / has failed and you should pop a breaker. E=I/R P=E*I. Simple math R = Load is controlled by the consumer. P = power, is going to be the voltage provided by the panels (E) times whatever the MPPT is pulling (I) which depends on load (R).Well, that’s over 10% over the rated. I’d let others chime in if that’s excessive or not
I’m not going to come out and advocate for someone to exceed specs. I don’t think it’s complicated but I have my own plans as well lol.This is not complicated.
Adding load, aka lowering resistance, does not necessarily lower voltage, and could simply overload the output frying something. If you want to lower voltage reliably you will need an inline voltage limiter.So I'm wondering, seems like there should be a simple votage monitoring circuit added to combiner box when over paneling, that would kick some output to a big resistance load like perhaps a DC Shunt breaking resistor?? That would acts as a safety mechanism rated for long duration (unlike the SPDs) only activated in the 500-600vdc range. Why don't I see something like this? Basically it could then allow added safety over volt protection at the DC side. This is EE territory now, which I am not!
What happens when one of two or more parallel panels or strings have a short or fault condition? I would think this could cause you some grief as the good panels start pumping their juice at the Zero Ohm load they are in parallel with. I would put a secondary diode for each tied connection at the + junction in my combiner box. we are talking $1.00 or so per wire.
As @Zwy keeps alluding to, at some point overpaneling is wasting energy. Idk if that threshold is 5%, 10%, etc.
I will say, it is more complicated than you lead on as for example a low frequency Growatt or sigineer absolutely can NOT be overpaneled by wattage nor voltage.
I agree... But earlier you said...If you had several strings in parallel, each with a fuse, then if there was a short and current exceeded fuse rating sufficiently, it would blow.
With as few as two strings in parallel, or with more, there was a short bridging some PV panels, or shorted bypass diodes, then current would flow back through it perhaps without blowing fuses (if any). With two string, current would be limited to 1x Isc, so wires don't overheat. But failed bypass diodes would. This could overheat the diode and cause damage same as they do with forward current.
Anti-backfeed diodes would protect against overheating bypass diodes that way. Nothing prevents them overheating with forward current (you're supposed to avoid hard shadows when in full sun.)
I must have a context problem.Parallel doesn't require diodes either. Up to two strings parallel, no fuses/breakers required.
Reality is you will not get anywhere close to the rated output of your panels for any realistic length of time. I live in Phoenix, and it may be hard to believe, but it's REALLY sunny here. I should be able to pull 14560 watts from my 32 panels. I have seen numbers right at 14000. Right now I'm lucky to hit 9000.
I consistently pull full output from my strings. Of course, I optimize array angle for the sun horizon per season, no shade. I also see by 9 AM about 1/3 of my array power coming in during winter season if there is sun.
Of course, I have to ask, what panels, series and parallel strings, any shade, panel angle and quite a few other questions.
I'm pulling 40Kwh easily off 8420W of panels when the sun is out here in late fall/early winter but skies are clear with no dust or haze helps. Only days I run my furnace is when 2 or more days of no sun is in the forecast. I only charged the battery bank 8.5Kwh yesterday and 2.9Kwh today. On November 30th, I not only supplied 28.8Kwh for loads, I also charged the bank 18Kwh. November 29th was 21.7Kwh load and battery 27.2Kwh.
I assume you're using home assistant?455's are on the roof, fairly optimal, maybe 5 degrees too flat, due south.
Targets:
8*455 = 3640
8*250 = 2000
7*250 = 1750
32*455 = 14560
8*15 = 3750 (Used, sub-optimal orientation)
T = 18310
On 8/27, it was bright, clear and sunny all day . . . You see A|B-PV1|2 should be able to hit 3640. I do see strange spikes from time to time, discussion below
I see radical spikes, on cloudy days, I think it's due to a capacitive state in the panels while the MPPT ramps up/down. I'm guessing that since the demand was there, this allows a more immediate discharge, The spikey numbers occur as the clouds light the panels back up. So while I've seen numbers that exceed theoretical max (see below) it only happens when I'm getting volatile readings, which are extremely short lived
On 8/14 we had a lot of broken monsoon clouds
And overall production on those days is comparably poor.
I'd be willing to bet if I was overpaneled on the 14th I would have seen a pretty linear benefit from the extra panels, despite the supposed high output numbers. Using an average peak of 3000 from the 27th, a very good day. (Which I actually think is probably high).
100 - ( 3000/3650 * 100)
17.8100
I could over-panel around 20% to generally hit the theoretical spec on a perfect day, and rarely even clip, if at all. That gets back to the 95th percentile stuff. Over the period where ideal production can hit 50% (?) or better what is the sample at the 95th percentile? Is that low enough? Unless you have your panels on a tracker and/or highly optimized, I'm guessing around 25% in a normally sunny environment would create a mostly linear improvement in output. I think the spikes I see in output would mostly just flatten if the MPPT didn't take the current. I think the loss from clipping would be minimal. The larger the percentage of time below whatever threshold you pick the more linear the benefit.
I could be full of it, but in my world, I just don't see it. I'd love someone to show me a graph that shows their panels hitting 100% of rated output for more than a 5 minute interval. Neither do I think the vast majority of panels are 100% optimally facing all the time, but you can only flatten that solar curve so much.
When I have a bit more data after this summer, I plan on doing some percentile calculations.
Grafana, custom everything.I assume you're using home assistant?
I really need to dive into that. Really nice graphs.
Angle is not optimal for August, it's on my roof ~ 10 (2/12). I will not be tilting them. I was not recording until August, so we shall see...I think there is something wrong with your PV. Could be you aren't maximizing string voltage for example. I run JA Solar 530W panels, my Vmp is around 360V, this keeps amps low and less power loss. Or the angle is too flat. Something is wrong with it, I would expect to see much higher PV input.
