42OhmsPA
What's in a title?
+2!+1!
Been watching for 10-12 kW parallelable unit with low-ish idle & price...
+2!+1!
Yes, patience is a virtue.....so they say....Ya, I know - gotta be patient, - not by strongest trait !
I was looking at a Amensolar 10kW unit that is reportedly low idle (50W) and parallelable, not a bad price (just under $2k each) but it seems these units share some bits with MUST inverters (I am told) and that worries me given the software problems people have reported on the MUST inverter series. Patience Patience Patience - But it's November and idle currents are eating up too many kW's each cloudy day...Patience...
Now I have to wait for that new 12k to come out, then wait for people to get them and try them out, see if any issues show up...ok everything is working - just let the MPP's run, and do their job...see what RedNeckTech is up to...
I've been thinking what I should use for powering the shop. this just might be what I will install. I'm not in a hurry, it probably would not be until late next year before I start.
excellent! - we can all watch for your install, and what you find running that new model...beta testing for us!I've been thinking what I should use for powering the shop. this just might be what I will install. I'm not in a hurry, it probably would not be until late next year before I start.
Things sometimes move slow around here when it comes to projects, work can get in the way.excellent! - we can all watch for your install, and what you find running that new model...beta testing for us!![]()
Not really, just ideas...I have connected the Battey BMS with RS 485 and when the battery is fully charged Error 64 BMSovervolt is appeared. Do you have any idea why it happens? My battery is 51.2 200AH Lifepo4 and I have set the LFP 16 battery type.
Not if I order one first ?.excellent! - we can all watch for your install, and what you find running that new model...beta testing for us!![]()
Thanks. My battery is SRNE Lifepo4 battery. Also, you can run 1hp well pump without problem and it has 40A(8000W?) inrush.So, is that one 220V pump? I have a 1.5hp surface jet pump for deep well. Could the 10KW Inverter handle the surge load when other loads are not running?Not really, just ideas...
What battery / BMS? What is your bulk charge voltage?
I suspect the BMS is programmed to charge to aggressively trying the take the cells to 3.6V or higher, I also suspect the cells are out of balance; which is causing a cell to 'run' and throw the BMS error.
I'd suggest forgetting about BMS communications, set battery type to user, bulk charge to 55.2V or 55.6V and float at 54.8V.
I'd also suggest establishing BMS communications with a PC so you are able to see individual cell data.
If you disconnect the BMS from the inverter without setting battery type to user the inverter will throw an error but it will still function.
Oh an welcome to the forum.
I've looked at them but I can't bring myself to purchase a pre-built due to the cost savings of building my own. Someday, maybe.Thanks. My battery is SRNE Lifepo4 battery.
Yes, 0 issues running it along with the rest of my house. I see no reason the inverter couldn't handle it, however your limiting factor may be the BMS in your battery. I have 3 batteries in parallel, I did test running my pump with 1 battery using 305ah cells and a 300a BMS, there were no issues.Also, you can run 1hp well pump without problem and it has 40A(8000W?) inrush.So, is that one 220V pump? I have a 1.5hp surface jet pump for deep well. Could the 10KW Inverter handle the surge load when other loads are not running?
Give her / drier their own inverter and battery. Have it set to only power up the drier when there is enough electricity in it for a load. Charge it's batteries however you want. Expensive, yes, hilarious, yes.I didn't implement the "simple display" part - at least not yet!
I have to figure, will I put up a small monitor showing the Solar Assistant main display - shows the battery level loads and how much incoming solar all on one easy view,
Or set up a Red Light - Green Light above the dryer - above 52 volts = green otherwise Red?
What do you guys think?
she picked the Tablet option - just in time for Black Friday no less...Give her / drier their own inverter and battery. Have it set to only power up the drier when there is enough electricity in it for a load. Charge it's batteries however you want. Expensive, yes, hilarious, yes.
is the over-voltage error for the whole battery voltage? - then check that the inverter charging parameter isn't set higher than the BMS max voltage setting.I have connected the Battey BMS with RS 485 and when the battery is fully charged Error 64 BMSovervolt is appeared. Do you have any idea why it happens? My battery is 51.2 200AH Lifepo4 and I have set the LFP 16 battery type.
Not that I'm aware of.Do these inverters use frequency-shift load management? I read through the manual and didn't see any mention, so I'm assuming not. I've got Enphase micros on some panels that I'd like to keep.
I played with where on the main bus the battery pack connects, and with what ga. wire, and got my lower and higher Ah packs to stay closer to same SOC over the charge/discharge range. I have two 100Ah server racks - connected these up parallel and run pos from one to pos bus, and neg from the other to neg bus, using 4AWG wire. The other packs are all DIY 280's and 304Ah - those are connected with 1AWG.Looks like I need to connect to the BMS's with the laptop and reconfigure my voltage %s that I just had to tinker with...
My shunt is showing over 30% soc.
Thanks I'll check that out as well.I played with where on the main bus the battery pack connects, and with what ga. wire, and got my lower and higher Ah packs to stay closer to same SOC over the charge/discharge range. I have two 100Ah server racks - connected these up parallel and run pos from one to pos bus, and neg from the other to neg bus, using 4AWG wire. The other packs are all DIY 280's and 304Ah - those are connected with 1AWG.
To play with where a pack connects to the main bus, I used a vise grip to just clamp the ring terminal onto the copper bus, and moved this set up away or closer to the main 4/0 wire that goes to the Inverter's bus connection. The vise grip gave me a way to try spots without drilling a lot of holes for testing. maybe you can do this too.
For comparison purposes. I only have slightly over 6kwpCan't wait for my pallet of panels to show up.
Looking forward to sunshine tomorrow, might make it until then...
Good info.Also something maybe worthy of note. I complained to ali baba about my wrong model number and they sent me the UL certification, which covers both models. Same exact inverter confirmed
