12VoltInstalls
life passes by too quickly to not live in freedom
I previously posted a mention regarding this https://diysolarforum.com/threads/water-in-diode-box.27888/
I wasn’t sure the diode boxes were leaking but it appeared that way. No matter; damage was done.
The other morning (in the course of re-proving to myself that I more amps are available for charging under poor or early light with series panels over parallel) I discovered a third!! panel with water in the junction box. grrr
(BTW WindyNation has been great)
Not only that but lots of water was inside several of my MC4 connectors- again. Complete with rust/corrosion.
I fixed it all but it appears that it is posdible that the MC4 orings are leaking, and re-closed the junction boxes with lexel (bad idea long term!!) as they could be leaking. Or not?
Checking everything with extended scrutiny I suspect that I may have found the culprit: the compression seals over the panel and cable wires among various brands is essentially not tight on the insulation sheathing. Hmmm. Which leaves the ponderous conclusion that water is getting into the wires from the MC4 connectors and migrating several feet into the diode boxes!!?! though the orings themselves are not leaking.
FWIW it appears that the oem WindyNation panels do not leak at the wires but I can’t rule that out. It appears that Bouge RV MC4 stuff mates fine to WindyNation MC4 stuff. It also appears that of the various other three or four “brands” of MC4s I’ve used either break or leak because they do not seal to the cable sheathing adequately.
At this point I think most or all of the windynation, none of the Rich Solar, and all of the other “brands” of MC4 have been replaced with Bouge RV MC4s. Bouge, once tightened, will not let me twist or wiggle the cable in the fittings.
This is driving me mad!
Has anyone else seen this problem-water in the wires? After I cut off an MC4 I can whip the wire against the building and get almost a half-teaspoon of red/brown water droplets out of it.
@chrisski mentions confidence even in under water situations (not happening here!) so I’m perplexed. Where is the water coming from? Why? Are my observations of moveable wires in fully tightened compression nuts accurate?
I’m not used to having problems with my installs ever. No redo’s in boats, utility trailers, or offroad vehicles. So to have this issue with idiot-proof connectors is exceedingly annoying to me.
I use Anderson Pole and MC4 to connect portable panels. On the RVs portable panels where it could get wet or be submerged, I use MC4s….%snipped… For that type of waterproof, I'd like an MC4 connector. If not MC4, something with an IP rating. Basically means it can be submerged in a few inches of water without leaking. Not sure Powerpoles meet that criteria.
