What 24V 200Ah battery do you recommend ??
ghostwriter66
"Here - Hold my Beer"
EE from LAX CA -work in SouthTX for giant evil Oil
Hi again from the laziest engineer that you will ever meet --
I need to purchase (6) of these ... (Have zero time to build them))
Would go with signature solar since they are in Texas ((@SignatureSolarTech)) BUT they do NOT have a heater in theirs - seriously - its 2023!! (PLUS we are still waiting for them to fix the 5KW Chargeverter we sent in month ago so not the top of our go-to list for the moment))
NEED a BUILT 24V 100aH OR 200aH LiFePO4 battery -- with heater -- and a solid BMS. Be nice if the BMS had BT
We can parallel 2 - 100Ah if needed to get 200Ah but would rather not.
We have (3) oil field remote sensors that these will go into -- (2) batteries in each sensor. Once we set the sensor out we NEVER ever touch it again - so batteries needs to solid ...
THOUGHTS???
Chins seems to be working OK for forum members. What this model lacks is the heating function and bluetooth.
12 volt models can have the heating function and bluetooth.
If you buy a pair you can go around joking about your double chins.
...Would go with signature solar... BUT they do NOT have a heater ...THOUGHTS???
Get the signature solar with the enclosed rack, put a strip heater with a thermostat in the enclosure powered by the battery, slice up the styrofoam beer coolers no longer used, duct tape them to the unit for extra insulation. Or, you could use the pink stuff from home depot and the boys probably won't touch it. If the heater fails, the batteries still have a temperature sensor. They have a small 3 battery enclosure (leaving one slot for other stuff like a thermostat), but you might be able to find a third-party insulated enclosure.
I would look at Roypow. Will Prowse was impressed with the build quality of the 24v marine battery and the 48v golf cart battery.
They have 24v 200ah LFP systems with heaters designed for aerial work platforms (scissor lifts)
http://www.roypowusa.com/?page_id=38517#bit_twf81
And for floor cleaning machines
http://www.roypowusa.com/?page_id=38452#bit_twf81
They have an office in Richardson Texas
http://www.roypowusa.com/?page_id=16479
If you choose to parallel 100 ah batteries, Bluetooth is available for the 24v marine trolling motor battery https://roypowcell.com/products/roypow-24v-100ah-lifepo4-battery-for-trolling-motors and from the lower priced Epoch (which I gather is owned by Roypow).
