What part of the state? I'm in the western panhandle.Always looking for other FL off-gridders to connect with.
Our propane refrigerator works for us, but we also have a small portable electric fridge as backup and in case we need to evacuate because of fire (and have the time to pack that kind of item). This discontinued model is also able to cool with electricity but it is not efficient at all; heating a coil to utilize the same system that the propane uses. It did fail, perhaps because we did not have it completely level, but the bouncing during transport to an RV service shop somehow got it to work again! The interior light was run by D cells but was broken before we bought the place. I have a motion sensing light powered by Ni-mH batteries instead.unsure if this was addressed to me, apologies if not.
have not considered or evaluated that type of fridge as of yet.
that type requires two inputs, is that right? liquid petroleum and electricity.
for my situation, extremely long autonomy without maintenance of any kind is the highest priority. even with a large reserve tank, that type would require occasional refueling right?
kind regards ?️
Southwest. Inland Charlotte county.What part of the state? I'm in the western panhandle.
thank you for these additional insights?Our propane refrigerator works for us, but we also have a small portable electric fridge as backup and in case we need to evacuate because of fire (and have the time to pack that kind of item). This discontinued model is also able to cool with electricity but it is not efficient at all; heating a coil to utilize the same system that the propane uses. It did fail, perhaps because we did not have it completely level, but the bouncing during transport to an RV service shop somehow got it to work again! The interior light was run by D cells but was broken before we bought the place. I have a motion sensing light powered by Ni-mH batteries instead.
Curiously, our little electric fridge (also capable of temperatures below freezing in its single chamber) will shut down when our modest lead acid battery pair sags deep enough under load at night, but our Morningstar 300W inverter will keep silently chugging all night with the same batteries. Know that the compressor goes on for a few minutes then stays off for significantly longer.
Even if one is using propane for cooking and supplemental space heating, all of our off-grid neighbors (been here for decades) have transitioned away from propane refrigerators and use local store bought efficient units, increasing their solar energy capabilities if necessary.
We must defrost regularly (maybe twice a year, probably should do it more often). Condensation from the cooling fins in the fridge chamber has a system that drips out the back into a tray where the water evaporates. The propane flame is not vented outside; our house is not air-tight.
Just saw this too, sent you a PMI'm another Florida self-build. Curious - are you going to be completely off-grid?
EDIT: just saw on another thread that you are indeed fully off-grid. What stage are you at, and have you had any County issues with being fully off-grid? Always looking for other FL off-gridders to connect with.
Adding batteries is not too difficult as you say. I will buy enough UL listed to satisfy my AHJ and then add my DIY batteries after CO.I undersized my battery bank...mostly due to budget issues.
One thing I am extremely grateful for...we didn't do roof mounted PVs!!! I kept the roof integrity intact and the PVs on our ground 2 mounts are accessible as needed.
Yes it is. This is from the OP:FUNNY, the OP ran off from this thread after Post #13 when everyone started the whole Pool Pump pile which is NOT THE TOPIC BTW !
Discussion on pool pumps and suitability for off-grid systems is right in the wheelhouse for the thread.Cook with induction or propane?
Passive rooftop water heater or several small instant heaters?
Pool pump choice/programming?
Lighting?
Smart home stuff?
Frig/freezer choices?
Worst advice I've ever heard on this forum or anywhere really lol We've been off grid since the mid 1990's and energy efficiency is king.Don’t spend any extra on energy efficiency, put the money into your power system.
Size your batteries for one nights maximum use only, and use generator power as required.
have a woodstove as well, so no running the exhuast fan when trying to get a fire started
Air leakage came at 0.6 ACH. so its tight, but then you have to mechanically ventilate, and I have a woodstove as well, so no running the exhuast fan when trying to get a fire started (ask me how i know how hahahah).
Basically the 5 gotchas i experienced:
... and 4 girls!
They like to use things that make heat, hair tools, coffees, leaving lights on etc...
5. Check the prices historical on propane and then make calculation. Here propane is still more cost effective than a whack more batteries and solar power and inverters.
This is one of the reasons you should have an air intake coming directly from outside into your fireplace. The other reason is so you don't blow already heated air from inside out of the chimney.
/cold climate represent
Would it make sense to reverse direction of ventilation fan (run house at positive pressure rather than negative pressure)?
What are the odds? (1/2)^4 = 1/16
Can you find a way to get them to dry/curl hair while the sun shines?
We'd like to do thermal storage, some discussions on it but not clear there is an easy solution.
If they are wannabe climate heroes then you might have a chance to appeal to that but else it's a brave man to take that task on. Good luck!Can you find a way to get them to dry/curl hair while the sun shines?
Every now and then my wife uses something in the evening (like put on the clothes dryer) which makes me go "ugh" but sometimes you just have to "let it go". And it is why I am glad the heat pump appliance we do have is very efficient at what it does, we can get away with that if we need to do just that. If the day is nice the clothesline uses both wind and solar power and costs absolutely nothing to run.
in a sunny location with space for photovoltaic panels, the need to power optimize is reduced.Worst advice I've ever heard on this forum or anywhere really lol We've been off grid since the mid 1990's and energy efficiency is king.
