I apologize first off because I know that someone else had this question/problem also but I can't find the thread. I tried to deplete my battery (fully charged) to see how long I could run my space heater or a high watt appliance like my insta pot. I ran the heater (1100W) for 2 minutes and the battery circuit breaker tripped( I have BattleBorn 2(100A) with 250 amp fuse; second time after reset the inverter fuse tripped after 3 minutes (inverter is 3KW/6KW) with 250 a fuse. Nothing on the setup was hot but extension cord was hot. Battery was instantly depleted to half per meter. Any idea why? The fuse should be higher? Wires are 2/0 (battery to busbar and busbar to inverter).
I also tried a heat gun(3 minutes before disconnect) and my hot pot for heating water (that was the longest of 8 minutes before disconnect) Thanks in advance.
