DZL, you answered soooooo many questions with that one visual.
I almost want to cry.
Thank you VERY much. ????
One can also use the green lines to get an idea of where there [about] 10 to 0% is as well after balancing.I feel you! My own struggle to fully comprehend balancing for so long is what led me to make that visual aid, and helped it all 'click' in my mind. Glad its helpful for you and others too!
Also if its not clear from the image, the green line in the unbalanced pack is the reduced usable capacity due to imbalance. The red line is the usable capacity of a balanced pack.
Maybe a silly question but do you need a charger to balance cells? Or can it be done some way without? My battery will be charged via solar so don’t want to buy one Just to balance if I don’t have to.
You need a charger to do it properly.
A less ideal alternative, but not dangerous as I understand it, is to skip the initial top balance step and try to let your BMS balance the cells over a long time period (weeks? months? forever? idk), so long as you understand that your pack will take a long time to balance and will have some amount of reduced capacity until it becomes balanced, and charge and discharge cutoffs (at the inverter and chargers) may need tweaking since pack and cell voltages may be out of step with eachother.
Thankyou for this. I saw that Will says you can let them self balance in his balance lifepo4 cells quickly video. My cells are new and it’s only a 12v 4s system so hopefully they wouldn’t take too long.
Do you know what a acceptable difference between cells is?
Ah ok, they are 280ah cells. No idea regarding bms I’m afraid. Maybe it would be easier to just buy a power supply and top balance theM that way.I think as important or more important than voltage and number of cells, is capacity of the cells and balance current of the BMS (as well as how well matched the cells are).
Sorry, I don't. And it would depend what you are referring to.
Haha yea was actuallyjust thinking the same thing, I do like to tinker so no doubt il find other uses for it.Personally it is what I would do, starts you off on the right foot. I feel your pain though (as do many others) its frustrating to have to spend money on balancing equipment that you may only use once or twice. Of course if you like to tinker, there are probably other uses you can find for a power supply.
An initial top balance is a good idea, particularly considering that you have large capacity 280ah cells. I've noticed a lot more people buying active balancers after buying 280 ah cells over the last few months, which gives me the impression people are finding their BMSes are not able to keep up with large capacity loosely matched cells. This is just my anecdotal impression based on what I'm seeing on the forum (and some comments Steve S has made about voltage differences upto 1-2 mV per Ah with the 280 EVE cells), I'm not sure if its accurate or not. But if it is, it makes an initial top balance even more important because your BMS will already be struggling to keep the cells balanced.
What BMS do you have or plan to buy? I can tell you the approximate balance current if its a common BMS.
One other use:Haha yea was actuallyjust thinking the same thing, I do like to tinker so no doubt il find other uses for it.
Definitely want to start out on the rite foot.
I have this bms, it’s the one that will recommends (or did). View attachment 24156
It being low does that mean it would take a age to self balance?That is a JBD Smart BMS, can't quite make out the serial number but looks like JDB-SP04S020 which is the 4S 120A version (like you said, one of the models Will recommends). I believe the balance current is in the ballpark of 50mA which is pretty low
