kolek
Inventor of the Electron
- Sep 29, 2021
- 902
Ok, that's interesting, but it doesn't answer my question. Say I want to divert power to cycle my AC. That device is not gonna do it. You'd need to create a robot with solenoid controlled fingers to physically push the buttons on the AC's remote control. Most household appliances aren't expecting to be hooked up to and controlled by a Triac.No, I use a similar Triac based system and you can feed any AC resistive load which in my case is a 3kw immersion heater but it can also feed two 3kw loads if you add a second Triac.
My question is, when you divert I assume you need to start with a primitive device that turns on when you apply electricity and turns off when you remove electricity, with none of the typical user interface you typically find on household appliances?
