Bananaman321
⚡solar idiot ⚡
Any thoughts on panels degrading faster used on trackers being that they spend more time at Maximum sun exposure
I can't build any of that for $400. I think a few here were going to try them but I've not seen how they worked out for them. It was going to be for supplemental, while I'd have a stationary South facing array I'd like a small tracker to pick up the early morning sun and setting sun in the evening.By the way if you got room for that crap in your yard why not just build a solar carport or a solar gazebo or a solar lean to.
If you could look closer you would find the "hinge" pins that connect the linear actuator to the frame and the "hinge" mounts are not very sturdy. In addition the linear actuator is mounted so close to the pivot point (fulcrum) that any wind load places very large forces on the linear actuators and more important their mounts. The further the linear actuator mounts are from the pivot points the less degree of motion they provide.Ok, I was just curious if having the PV string / circuit loaded up and all that current not being used was a issue outside if just being wasteful.
As for racking, I was looking into one of these trackers; I believe you can put full size panels on it ..so 8 400W panels would be nice. Wouldn't that make up for not over paneling?
Dual Axis Solar Tracker System Help To Increase 40% Power | ECO-WORTHY
ECO-WORTHY dual axis solar tracking system can control the dual-axis linear actuator to make the solar panel to follow the sunlight, Keep the solar panel always face the sunlight. Production from a dual-axis solar tracker will increases annual output by approximately 40% compare to a fixed solar...www.eco-worthy.com
Haven't given it much thought since I have a bunch of very old panels that still work great. Also the used ones I bought from santan have done awesome too. So I just want to get the max out of the panels possible. Also with these being bifacials I'm going to put on the trackers it might work even better. Votes still out I think on bifacial panel lifespan.Any thoughts on panels degrading faster used on trackers being that they spend more time at Maximum sun exposure
The ideal setup would be a fixed tilt mount with full tilt tracking then the entire thing on a carousel like modern microwaves haveIf you could look closer you would find the "hinge" pins that connect the linear actuator to the frame and the "hinge" mounts are not very sturdy. In addition the linear actuator is mounted so close to the pivot point (fulcrum) that any wind load places very large forces on the linear actuators and more important their mounts. The further the linear actuator mounts are from the pivot points the less degree of motion they provide.
Will be good to hear the results, with all costs (install, maintenance and longevity) factored in .I'll be experimenting with fixed vs the trackers for this winter. I want to see if it makes a worthwhile investment for some extra ummph in the winter time vs fixed mounts.
I'll list what I spent but you all can crunch the cost vs performance numbers. I'm just interested in the tracker vs the control group of fixed panels performance numbers each dayWill be good to hear the results, with all costs (install, maintenance and longevity) factored in .
Ok, thanks for that feedback. I wonder if there's any quality trackers for a decent price. I know there's a few here that built there own, one gent built it with his son but did say it wasn't cheap but I think it mostly had to do with the motor he chose.If you could look closer you would find the "hinge" pins that connect the linear actuator to the frame and the "hinge" mounts are not very sturdy. In addition the linear actuator is mounted so close to the pivot point (fulcrum) that any wind load places very large forces on the linear actuators and more important their mounts. The further the linear actuator mounts are from the pivot points the less degree of motion they provide.
Normally I would agree but since it will just be powering a backup charger that charges the batteries I won't cry if I have to throw a few panels on the ground because the tracker barfed.complexity = higher maintenance, added systems and components to fail all of which cost more time and $$
If it's just power in your tool shed and I say have fun and go for it. But as reliability standpoint I'm sticking with fixed mounts there's enough other equipment to maintain without adding to it.
