Thinking about expanding my system and pondering the following questions for any Deye / Sunsynk or I assume SolArk users out there...
a) If I deploy a SUN-6K/8K-SG01LP1-EU inverter with PV input in grid-tied configuration and move my existing 14.3kWh battery pack to the Sunsynk, will the Sunsynk charge its batteries from any grid export it detects that has been generated by another grid-tied inverter (in my case a Solis, but with batteries removed) supplying the same 230V phase? This is what would happen if I were deploy another Solis, but just considering my options at the moment. Using the Sunsynk's gen port is not an option as the existing Solis will need to remain grid-tied as it will be running without battery.
b) Does the Deye / Sunsynk work with a remote RS485 and CT clamp based Acrel power meter? Documentation seemed to imply just a directly connected CT which is not an option for me, though the 'ecco' range mentioned power meter, but not details of the meter or configuration.
TIA
TIA
