Getting way too ambitious with my latest upgrade. I had decided I wanted to redo my sub panels setup that previously was wired from the Main panel and my off grid AIO through a manual transfer switch with AC in power tapped off from main in the switch box. I decided I wanted to keep main power in the sub panel so that I could have a 240v heater powered without the necessity of switching off the solar to other loads in the sub panel. My AIO is only 120v.
This means that I needed to bring power from the sub panel for my AIO and I decided to add another AIO to the mix so that one or both could operate and AIO 1 could be switched for AIO 2 loads and it turned off when trying to reduce idle loads. I added 3 MTS circuits to power other sub panel loads. Since I was using the A (lever down) side of the MTS for grid power, and the B side (lever up) PV, power and neutral from sub panel had to feed through and also power and neutral from AIO #1 AC out had to also. Neutral would be switched this way for each circuit. Providing circuit protection would be breakers.
Wanting the AIO's AC in to be powered off different legs of the sub panel also required working out breaker protection. Than there was Neutral and ground to deal with. It took many hours and I just got it all turned on about 2 hours ago. The transfer control box wiring (rats nest on top) does need some cleanup and i need to make up a instruction sheet to be taped into the box lid so what each thing does is explained. All in all I have about 10 hours into this thing so far. Everything works and is functional but I am still in the, "Did I screw up", testing phase.
