Worth combining cells from two (2) 12.8V bats into one (1) 25.6V?
AC/DC
Dallas
New here, and this is my first post! I'm just getting started and bought two (2) EcoWorthy 12.8V 150Ah LFP batteries. I'm using them in 2S for a 25.6V 150Ah battery and I've just run a test of charging my Tesla with my 24V inverter and it worked great. Everything except one of the batteries cutting out first (BMS low voltage cutoff). The particular battery which cut out first seems to be less stellar than the other, and I did have some questions about some internal stuff I found (maybe I'll post depending on replies), but I am not thinking.. is it worth considering using the cells from these two batteries to build a single 25.6V 150Ah battery? Here's my thought process:
Pros:
  • Can charge it all at once w/o having to worry about two BMSes on two separate batteries
  • Can upgrade to a nicer BMS with Bluetooth/etc. where I can get data on cells and stuff — for fun, at least, this is appealing
  • Passive balancing would work properly vs.. not at all, unless I manually charge each 12V bat (which is what's going on at this very moment)
  • In general, just not having to worry about two bats
Cons:
  • The metal case each battery came in is actually quite nice. I'd hate to waste them (and there's no way I can fit two bats' worth of internals into one case)
  • The BMS in this model is decent, despite not being "smart" (no BT/etc.). I made some rookie mistakes and it protected the battery and me safely. I'm impressed, not making any particular claims but does the basic things very well
  • Having the ability to take just one of the bats with me with a smaller 12V inverter can be a use case. Or heck even take it for a ham radio outing (where lugging a ~50lb bat isn't a problem) and give power to everyone :)
  • Not having to spend additional money and time to buy a new BMS, figure out the new case solution, wiring, etc.
  • While most of my existing chargers are 12/24V capable, at least one is just 12V. I couldn't use it for this anymore.
Anyway this is also just to have the conversation and get some ideas. I don't even know what I'd do for the case. In the back of my mind I'm thinking that one option is to somehow glue/fuse the two cases together, make some holes and install a new BMS in just one of the two, while it would connect to the cells in both. Another option is just to keep trudging along with the way it's set up now and keep learning/improving how I deal with this kind of situation.
What do you think?
An 8S battery will only be as good as the weakest cell (+ any help from balancers).
Do you have any info on the voltage of the lowest cell (likely the cause of first batter cutout) ?
If you can provide any info on this it will help make a call on what is best.
If you have 4 good cells and 4 mediocre cells, ranging them as 2x 4S batteries, will best cells in one, worst cells in the other, is not a bad solution either.
Most people who have been doing solar for a while pretty much all started on 12v systems. Mainly because 12v is familiar and easy to play and learn with. You won't get shocked by touching the + and - terminals with your bare hands on a 12v battery. It's easy to go to 24v. A lot of car/RV equipment run on 12v or 24v. And it doesn't cost that much. If you don't ever plan to expand beyond 4 batteries total, then you'll probably do just fine. But ask anyone here, it's addictive. You want to keep adding more and more. More batteries. More solar panels. Bigger inverter. A second or third inverter. Just more and more and more!
But most people who started out at 12v, included me, regret not going to 48v sooner. I wasted a lot of money adding more 12v batteries and then switching to 24v equipment, and in the end finally decided that 48v is the way to go. So all the 12v batteries, 24v batteries, 24v inverter, etc are pretty much useless for a 48v system. Yes, you can put 4 12v batteries in series to make a 48v battery, but it is not ideal.
Now I have a 48v system and very satisfied with my solar setup. I also charge my Tesla and a Nissan Leaf with it.
As mentioned above, a lot of folks start with 12V due to "general comfort" as it is more familiar. In reality, up to 48V is pretty much the same, after 48V things change up quickly.
We suggest that your battery packs are "Native" to the rest of your gear... Maning if you are running 24V Inverter then use 24V Battery Packs. Many folks do bodge together 2x 12V in series to make 24V but inevitably they hit problems that only escalate over time... There is an extensive group of those here... Batteries in Series can fail & most terribly in the worst cases.
Ideally, you install batteries in Parallel so that you have 2 or more 24V Batteries in Parallel.... That will increase the Stored Amp Hours but NOT the voltage. Any Load/Charge will then be divided "proportionately" between the packs in Parallel and that system then also becomes more fault tolerant, because if any packs shut down the rest keep going without effect.
Can you change those two 12V into a 24V ? YES
It would require removing the cells from the 4S packs and set that up in 8S config (see one of my diagrams below)
Replace the BMS with an 8S 150A BMS *** It depends on the cells and what they can handle... We would need to know what cells are within those 12V packs. If cells are 100AH cells then a 100A BMS is needed.
Unfortunately, the 12V steel boxes won't be of much use.
Something to Ponder: The general recommendation is to NOT Exceed 250A Draw from your battery system for a single inverter system.
12V X 250A = 3000W or 3000W ÷ 120V = 120V/25A (240V/12.5A) *
24V X 250A = 6000W or 6000W ÷ 120V = 120V/50A (240V/25A) *
48V X 250A = 12,000W or 12,000W ÷ 120V = 120V/100A (240V/50A) *
* = Uncorrected for looses & inefficiencies
Thanks so much guys, I'm a tech head and doing this for fun primarily, EE/electronics is my weakest area so what better stuff to "attack" to fill the gaps. Feels good to be part of a community where we listen, help and encourage eachother!
Yep, clear on that. I just think that with having to jump thru extra hoops to charge when the batteries have been depleted will only magnify the effect of the weakest cell(s). Yea I can keep charging each battery at 12V individually, it's just a pain, and they will keep getting out of wack if I charge @ 24V instead thru both at the same time.
Not yet, if I decide to proceed with this project that info will surface. I do have "fully charged" voltages (although I'm redoing right now with 14.2V charging), the "superstar" battery is at 13.7v after at least 30 minutes of rest, the "lesser of the two" battery is @ 13.5v (which is not bad actually, just unmatched).
So that's what I got now, 2x 4S (I'm pretty sure there's 4 cells in each box), but yeah I could further optimize I guess.
Totally. I did make some embarrassing mistakes which could have been dangerous (to me at least) on a charged 48V system. This is the primary reason I'm on 24V for the time being (and the fact that 36V doesn't seem popular, with few products — I'd be on 36V if it were).
Totally, trying to learn as much as I can, and get experience and develop safe practices, on the 24V system before building my own 48V at some point w/ prismatic cells.
I just charged my Model Y LR last night off this system until one of the batteries cut out! It worked great, and I will be repeating the test with some better cables w/ less voltage drop (due to having a 13A extension cord, I was limited to 12A). Inverter thankfully has a 120V setting so hoping I can push 15A at least (mobile connector will do 16A on proper circuit & voltage). Still like watching water boil considering I have a Wall Connector which will charge the Model Y @ 11.7kW+ on a good day (read: middle of the night when I'll get upwards of 245V @ 48A because there's little load on the grid), but seeing that juice come out of my very first off-grid setup is exciting nonetheless!
We suggest that your battery packs are "Native" to the rest of your gear... Meaning if you are running 24V Inverter then use 24V Battery Packs. Many folks do bodge together 2x 12V in series to make 24V but inevitably they hit problems that only escalate over time... There is an extensive group of those here... Batteries in Series can fail & most terribly in the worst cases.
Yea, I'm hitting some of these problems early on. I knew I would, I researched it, but still decided to take this path as my first adventure to learn. As someone who likes to optimize, it's definitely hard to even think that they're not native :)
What kind of BMS should I be looking at? I would think each battery has 4 150Ah cells since each is 12.8V 150Ah, unless there are some small cells and it's 2P4S — I hope this isn't the case as I don't want to string together 16 cells for a 24V battery.
Bummer, they're really nice cases. Though transporting the battery with a modified case using the original cases would likely prove problematic.
Got it. Right now I have a 3000W 24V inverter that will do 120V and it ran great yesterday with my Tesla Model Y as a test load, almost 3 hours @ ~1450W continuous. I'm hoping to be able to repeat the test (this is primarily a test of the inverter, with which so far I am impressed) with slightly higher continuous draw closer to ~1800W. At 1450W the draw from the 24V battery was between 60.9A and 62.3A, as voltage dropped.
When I was running a 24V system with a mix of 12V batteries, I read a post by someone here on the forum talking about wires getting too hot. Then I saw a video of Will Prowse using a thermal camera. I knew that my system was running a bit warm. So I bought a used thermal imager camera on Ebay for $100. Lo and behold, the combiner box I had was measuring 107F. That's too high for comfort. (see pic). I used a combiner box because 24V all-in-one SCC/inverters typically top out at around 150V PV input.
If you are drawing constant current (like charging your Tesla) for an extended period of time, you may need to keep an eye on the temperature.
After I switched to 48V, I did not have to use a combiner box because the SCC/inverter can accept up to 500V PV input. Even if I did use a combiner box, the amperage would have only been less than 8 amps. Right now with my 48V system, everything is running at ambient temperature. You couldn't even see a temperature difference between any of the wiring and the background.
