that is the issue. Like I said before, it's the installation - not the technology
When the fridge is in the slide - they never get any good airflow. Those fridges had been designed for being used with a roof vent - which they don't have in a slide. Just RV manufacturers not following the installation guidelines of absorption fridges.
RV refrigerators that are installed in the slide-out have a high failure rate, the Fridge Defend solves these problems and increases efficiency in hot weather.
www.arprv.com
Lot's of dangerous things when you put the fridge in the slide. 2 different power wirings going to the fridge and a propane line!! Now they are using a flexible propane line - which might with all the bending at some point.
In this case I would definitely recommend going for a DC compressor fridge. Absorption fridges in slides really hard to make work good.
