gyrex
Lithium Ion like the 18650 in my Vape Mods top out at 4.2V These LFP cells should be cut off at 3.65V. You don't gain any useful power above that. The only reason to charge to 3.60V is they will settle down to a lower voltage, once they rest. I'm perfectly fine with stopping at 3.5V. Even there I only gain an extra couple of hours at a slow drain. When you start using them, they will hang out at 3.35V(13.4V) for a long time.
Agreed - the discharge curve on LiFePO4 cells is extremely flat. My point is that the 280Ah claim of this cell is made based on a full charge and discharge of the cell from 4.2 - 2.5V at a low C discharge and unless one does tests within that range, we're not likely to see that 280Ah figure.
Obviously running these cells with these charge/discharge cycles isn't advised over a long period of time if one wishes to prolong the life of the cells since it breaks down the organic electrolytes at a much more rapid rate. Either way, these 280Ah cells appear to be awesome for large solar systems.
