Which way does the air flow in the EG4 18KPV?
I presume the fans on the bottom are the air intake. I presume this because updraft is best for cooling air flow and having the air turbulent (downstream of fans) inside the cabinet is best for heat transfer (breaks the boundary layer).
I can see the fans on the bottom in the user manual:
Where does the air come out? All the pictures I can find show no air vents on the front, sides, or through the connection ports. One wouldn't expect air vents on top for something rated for outdoors, that would be stupid. So where does the air come out?
The reason I ask is that I am planning to put this in a garage in Florida. The garage is not conditioned and can get hot in the summer months, exactly when the inverter is working the hardest. It will put out about 1 KW of heat on average based on the efficiency numbers I see. I am wondering if I direct that airflow outdoors so the heat doesn't build up in the garage. To do that, I need to understand the airflow behavior to see if I can collect it in a duct and send it outside. If I can do that, then I get the double benefit of dumping the heat outside plus increasing air exchange in the garage.
The manuals are, as usual, inadequate to figure this out. So where does the air go on the 18KPV? Can anybody take a picture of the exhaust ports? I couldn't find any online or in a video.
Mike C.
