I think you can local connect without an account. And update the firmware.Yes, you need to be logged in which doesn't help for people that don't have an account (and don't want to have one).
The 1 KW figure is the waste heat, not the load. When you are dealing with 12 KW solar/AC, the unit will pump out heat, about 1 KW or so. If I don't vent that elsewhere, it will dump into the garage and make it that much warmer. For example, battery to AC is 94% max efficiency. At 12 KW AC output, that's 766 wats waste heat, and that is assuming the max efficiency occurs at max load (which it very well may not be). Add in some PV power and you are easily at 1 KW heat coming out of the unit.At 1kw the fans want even come on. Unless they change the firmware. But if you net meter the fans will come on.
One summer is not an endurance test, of course. Heat reduces electronic part lifetimes. Electrolytic capacitors, of which I am sure there are plenty in the 18KPV, last half as long for every 10 C rise in temperature. So if your are 20 C hotter than you could be, the caps will last only one quarter of the time. So keeping the circuits cooler helps. An inverter in a hot garage will not last as long as one in a colder place, that's just the nature of electronic parts.The 18K will not turn on the fans until it's either doing 6 kilowatts worth of work or internal temperatures hit 140°. Mine is also in a hot garage in Florida and survived last summer with no problem, I was more worried about it than it was.
Good to know. Essentially, the "backpack" is basically just a duct with fans to direct air over the heat sinks.The exhaust ports are in the top of the unit and the heat sinks and fans are fully isolated from the internals, that is why it is IP65 rated for outdoor use.
Interesting, I am currently using RS485 but now I am wondering if I should move to CAN...Lux power inverters use CAN protocal. So for the 18kpv you’d use that. Markus with EG4 just recently made a video on how to change the protocal on the LL and pro batteries.
only remove if your installing an external rsd switchI don’t remember this being on my 1st 18Kpv. So this RSD cable gets removed?
On the subject of RSD, if I hit the RSD connected to 18, will that kill the feed from my AC coupled system by grid shifting it, or not at all, or some combo?
I know I can and will wire in the AC coupled system to the RSD, but just wondering in the interim.
CorrectWouldn't the EG4 just shut down once the RSD was hit, stop making "the grid", and the coupled system would just power down like a standard grid-down scenario?
No question, just a comment. Just went past 3 MWH on my 18 today, since November 23.
Open that circuit to shut everything down.I don’t remember this being on my 1st 18Kpv. So this RSD cable gets removed?
Yeah, this was through winter. Hope/plan to get a lot more through spring, summer and fallYou should have no problems getting way past that number. I'm at 16554 KWH of solar with 15307.9 of inverter output, implying around a 92+% efficiency overall. Not bad, and still not past a full year! Efficiency may drop a bit more, I added batteries last fall, which will get exercised regularly in the extremes soon.
