timselectric
If I can do it, you can do it.
- Feb 5, 2022
- 18,736
This is what you get when you pick the wrong installer.
Definitely not what I would use for batteries.
Holy cow, where do we start...
$149,000 of batteries... are they unaware of other options on the market today? 12V batteries in series? Yikes...
Scottās clients dictate all that just like this one did.And I thought Engineer775 installs were excessive. This one wins hands down.
Trust fund operator.My biggest question is what does ā Surfer dudeā do for a living to afford all that?
Riiiiiight?All that and still running a generator
It's all relative.And I thought Engineer775 installs were excessive. This one wins hands down.
That is 3 phase, not split phase.Would have been a perfect build for HV batteries and 60kw sol-ark
Seems they were almost starting from scratch. With that many outbuildings and acreage 3 phase could workThat is 3 phase, not split phase.
48?? I got 34 and I want to triple it at least.It's all relative.
Some of us wouldn't consider a 48kw system, excessive.
He means kW. Not kWh. 48kW of output is absolutely wild to me personally.48?? I got 34 and I want to triple it at least.
I meant excessive in cost of equipment used.It's all relative.
Gotcha. So that is like 3 of the best on demand tankless water heaters at the same time type of power.He means kW. Not kWh. 48kW of output is absolutely wild to me personally.
Donāt forget radiant heat floorsGotcha. So that is like 3 of the best on demand tankless water heaters at the same time type of power.
I definitely agree with that.I meant excessive in cost of equipment used.
There not, they have back up diesel generator tied in for back up.I'm surprised, based on location, that the batteries and solar are sufficient for winter weather conditions.
I missed that in the video; the wife kept asking many questions about the installation.There not, they have back up diesel generator tied in for back up.
If someone knows the location - what does PVWatts show per kW of PV for this area?
It's gotta be sponsored.$149,000 of batteries... are they unaware of other options on the market today? 12V batteries in series? Yikes...
