Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,480
I like that pic… I always favored the bad girls…..
Ahh … the sail boat days in the islands…I miss the eighties..
You might want to make sure the HOA is following Texas Property code section 202.010 in how they are resricting you.The easiest HOA approved location for me to install .....
Well, to be more accurate, you'd first need to ask permission from your wife, and I really don't see her being okay with you impersonating any 3rd parties or painting your body or face, so, well, so much for that idea. But I guess after she says no tho you can post to the forum here asking for advice how to convince her to accept your idea.Thanks Soggy. I will burst into the next HOA meeting painted up like William Wallace and demand our freedom.
PS. Whatever dose y’all on is correct dose.
Dilly dilly.
... and the Ecoflow Microinverter shuts down the AC feed if the grid goes down and then transfers to battery usage from the Ecoflow.
It is back feeding the house, will shutdown if grid goes down. At that point can power the loads with the Delta unit.I thought you meant backfeed house wiring from battery when grid was down (would have required communication with a disconnect switch at the meter), but that doesn't seem to be the case.
So I guess only downstream loads plugged into the battery inverter get backup.
EcoFlow PowerStream
Power your home, take power anywhere & go camping with solar generators & more.eu.ecoflow.com
EcoFlow PowerStream
