And DC House is $364eBay is weird with their deals, you really have to look at every single listing that a seller has.
On a separate listing, as a single unit they are still at the lower price-
HERE
HERE
Thanks. Looks like it's time to get a second one.Eco-Worthy version is on sale again, but not quite as good a price this time at $395.98. Make sure to use the right listing and the coupon code.
10 kWh for $1075 shipped* is pretty amazing if they're any good! I just spent that on a 5 kWh Vatrer battery.![]()
DCHOUSE 48V 50Ah 100Ah 200Ah LiFePO4 Lithium Battery Metal Case BMS RV Golf Cart | eBay
12V 100AH Lithium Battery. ãAdvanced BMS Protectionã. Batteries are easy to connect and batteries can be stacked upward to save space. The lithium battery can be connected in parallel. ãSmall Size Lifepo4 Batteryã.www.ebay.com
Memorial weekend Code puts this at $384.
I treat my single as a 50A unit.4x 50 Ah in parallel.
Do you find specs for charge and discharge current? (need to leave margin since may not split evenly.)
The Vatrer does give you access to cell voltages and pseudo soc on the display. I paid $885 for a gokw 5kwh rack mount with comms no idea when it's coming from China. They have a 14kWh for less than $2k.10 kWh for $1075 shipped* is pretty amazing if they're any good! I just spent that on a 5 kWh Vatrer battery.
* $1920 * .8 (Coupon) * .7 (Fed Tax Credit) = $1075 in a Tax-free state like Oregon.
Eco-Worthy's listing for their version of this battery (I believe they are identical) lists:
* 50A max continuous discharge
* 200A peak discharge
* 25A standard charge current
* 50A max continuous charge
* 200A +/-30A charge overcurrent protection cutoff
I'm not sure on the continuous vs max stuff. All of the batteries seem to show that now.+/- 1A
+/-5A
The margin might take care of imbalance. Might.
What is the significance of "standard" vs. "max continuous"?
Maybe impact on performance, operating temperature, of life specs?
