Purchased 2 of the lifepower4 24v batteries from them at the end of May '22. Received them at the end of June '22... problems from the very beginning. Their capacity was set to a 48v battery (100Ah. Should have been 200Ah) and the voltage seems to be regulated to 26.5v as it won't charge above that. Guy had me hook up to a PC enter a password into the QT BMS monitoring software and change the capacity settings. Cycled a few times and the voltage STILL regulated @ 26.5v. It's been 2 months of cycling and it still hasn't changed. They won't admit fault and keep telling me to cycle the batteries and the BMS will "learn" and stop regulating at 26.5v. I've never heard of any other battery doing such things.
... But let me say, if I've been irate with them at all... it's because I live in a van and I need this to work. Technically the batteries "work".... I just can't monitor how much capacity I have left at any given time, even if I were to add a Victron Smartshunt to them. I bought the batteries without the screen because I knew I'd be installing them in an area where I can't see them. The voltage is regulated after it hits about 20% - 30% SOC. Meaning once they charge to 26.5V at 20% - 30%, it stays at that voltage all the way to 100% SOC... I can't make sense of any of it. Nor can I get direct answers to my questions from their tech support. They just keep telling me to cycle the batteries... or that I need to contact my SCC manufacturer for charging config. I spent $3,222 on these batteries. So I'm a bit irritated that they're not working as advertised when I'm on the road. I'd be a little calmer if it was for a home build as a side hobby. But I'm relying on these for my main source of power. And as far as I can tell, none of the issues I'm having are due to any fault of my own. They just keep giving me the run around over, and over, and over, and over... ad nauseam.
Am I overreacting or are they gaslighting me? Has anyone ever heard of a BMS that regulates voltage, or needs to "learn" to stop regulating the voltage? This is completely new to me.
