Ohhhh right there's a setting they changed to make it not do that. We set it to zero so I only force discharge and do schedule charge if necessary. I forgot what the setting was called but if you call them they can change it.Does yours appear to always be in peak shaving mode? Unless I am in a mode that over-rides peak shaving such as "charge first" or am below my on grid discharge limit my system is always using the battery to match my load.
Doesn't matter if "peak shaving" is checked or unchecked, the time of day settings, or what the peak shaving power limit is. None seem to have any effect.
The only time any setting in the peak shaving category has seemed to matter is this morning when my unit did an AC charge for no reason, it limited the power to my peak shaving power limit.
I think you're the only other person on here doing grid interactive.
Oh right, I think we changed that setting as well hahaIn this case you would have the "micro-grid" setting checked.
Which still doesn't explain why the actual peak shaving setting would cause an AC charge.
Wait isn't that ideal? If solar can't cover my loads, I want the battery to cover the remainder. I'll read through your posts again. Not sure what's wrong in the picture.For fun, I just set every setting with a time option to 0 and unchecked the associated setting. Here's a screenshot of every setting:
View attachment 153432View attachment 153433View attachment 153434View attachment 153435View attachment 153436View attachment 153437View attachment 153438View attachment 153439
And finally, here's what I get when my load exceeds solar production. It's pulling from the battery. I have no explanation as to why.
It's not ideal in my situation. However Ideal or not it's still not following the settings. I do not have peak shaving enabled, so it should not be shaving. I've not seen any other explanation of why it's using batteries. The only way to get it to stop is limiting it based on some other setting such as "charge first".Wait isn't that ideal? If solar can't cover my loads, I want the battery to cover the remainder. I'll read through your posts again. Not sure what's wrong in the picture.
congrats on the new kidBeen quiet here lately.
I've now got my system installed in the permanent configuration doing 200A passthrough. The main new thing I'm able to test now is the "seamless" backup. IMO, it works great. Some of my lights I can see a flicker on changeover, but none of my electronics notice. 9 times out of 10 I probably wouldn't even notice the grid went down, which is awesome. Earlier today I did it while the dryer was running and 2 (inverter) window AC units among many other electronics. The only thing my wife noticed was the clicking relays when it happened.
Super happy to have this capability now, still losing power even with solar when the grid went down was always my biggest frustration.
Still waiting on Duke for the permit, but I decided I had to go ahead and finish the install, the wife is going to pop out a baby any day now. I need to get the battery cables in conduit then I'll post up some pics and take a review video.
I think either @Will Prowse or @Gavin Stone (or both) did a load on one leg in their video and it held up very well. Something like 75a on one leg and 14a on the other. I think that was Gavin's.How is it with unbalanced load?
Please explain this further.If you place the generator on the grid port...that leaves the gen port for smartload.
when I got my inverter last October, the grid peak shaving feature work like what says in the manual, but after couple update the behavior of grid peak shaving changed, i did all kind a test and i figured it out that it will charge the battery with ac, if the setting of kw is higher than the load of the inverter and it will charge it with that rate. I believe it does this to make sure there's energy on the battery for future high peak load...Can you expand on this? I don't understand why a grid peak shaving would charge the battery with AC when there's a setting group dedicated to AC charge. I've not seen anything indicating this in the manual either.
if everything is unchecked the inverter will be in Self Consumption mode, which the inverter will provide power to the house load with solar then battery (if solar production is not enough to cover the house load) then grid will provide power to the house load, if solar and battery is not enough.For fun, I just set every setting with a time option to 0 and unchecked the associated setting. Here's a screenshot of every setting:
I think that's my key issue right there. I personally want to be able to do everything myself without having to call up a support company to manipulate settings into what I want. IMO, the manual has too many places where it falls short.when I got my inverter last October, the grid peak shaving feature work like what says in the manual, but after couple update the behavior of grid peak shaving changed, i did all kind a test and i figured it out that it will charge the battery with ac, if the setting of kw is higher than the load of the inverter and it will charge it with that rate. I believe it does this to make sure there's energy on the battery for future high peak load...
That way of wording it actually makes sense and allowed me to recognize this section from the manualif everything is unchecked the inverter will be in Self Consumption mode, which the inverter will provide power to the house load with solar then battery (if solar production is not enough to cover the house load) then grid will provide power to the house load, if solar and battery is not enough.
if solar is more than the house load, it will charge the battery and export to the grid when battery is full.
if you don't want to discharged energy from your battery use (Charge PV first)(Charge Priority) use the timer when you don't want to discharge it.
pm me if you need help.
This is all useful.Here Is some more info im sure you guys will appreciate.
This is all useful.
From the HybridSettingGuidance:
Are you able to share the video or guidance for this function? Most of my confusion on the operation of this unit is centered around this one setting, so I'd love to learn as much as I can on it.
It worksI could see where commissioning can be a good thing if there is a problem or you cant figure things out and need help. So I'm wondering, will it work right "out of the box" when I get mine in a few days? I wonder if these updates from early on will have been made before it comes to me? If it works fine being used "just off grid" with "AC input only" when needed, and I will not need to commission the unit unless there is a problem?
I'm not so keen on some one making changes to the unit with out telling me first. Not so wild of leaving it connected to the internet all the time.
"commission" is a fancy word for "setting up" the inverter for your particular situation. You will need to "commission" it.I could see where commissioning can be a good thing if there is a problem or you cant figure things out and need help. So I'm wondering, will it work right "out of the box" when I get mine in a few days? I wonder if these updates from early on will have been made before it comes to me? If it works fine being used "just off grid" with "AC input only" when needed, and I will not need to commission the unit unless there is a problem?
