Screenshot of comment on that video says it well. The deceleration experienced by the smart cars occupants is deditorials.
Troll.
Which is worse: A) Two cars traveling 40 mph in a head on collision or B) A single car hitting a brick wall (immovable object) in a 40 mph collision?
Make it two identical cars. I kind of thought that went without needing to be said.Not to CRASH your litmus test ? but this question cannot be answered properly without knowing the weights of the vehicles in scenario A.
And please let BobB (I mean batshitcrazy) answer the question.Make it two identical cars. I kind of thought that went without needing to be said.
It needs a bigger hammer….. jeep hammer…. 1 immediately “ignores” other in a fake show. Fairly crazy to see ppl talk to themselves with different identity so understandable why one immediate ignore bans other. ?? Host of others on here suspect too.And please let BobB (I mean batshitcrazy) answer the question.
NO it does not.. Not only is the video irrelevant, its not even close. also, neither of those vehicles in his video were electric. All he did is post exactly what I told him not to.. that there is nothing we can do about a large heavy vehicle hitting a small one. I think my actual words were along the line of "Can't fix the problem of a semi-truck hitting a ford focus" or something like that.Well, if actual electric and gas cars were used it proves batvette correct does it not?
The physical size of a vehicle makes a huge HUGE difference.. in fact, of all the variables, its right up there on top of the list with speed, angle, etc.
Cars are designed to crumple.. the smaller the vehicle, the less crumple zone available. It is the crumple zone that mostly saves your life.
Double the impact time to zero, halve the g forces.. The more crumpling time, the lower the g forces. It is irrespective of mass or velocity.
It is the crumple zone that saves your life.. mostly.. Not entirely, but mostly.. Let me rephrase to be clear(er).. The crumple zone in front, irrespective of speed, mass, angle, weight of driver, or whether they bought regular beer or light beer, is among the biggest and most significant factors in the g-forces being applied to the squishy biological idiot driving the vehicle.I didn't follow 100% but let's say your fully electric honda civic crashes into your gasoline civic head on?
There is a difference. Mass does make a difference, I've never said it doesn't.. but on the scales we're talking about concerning EV's and ICE's, it is not a significant one.. and certainly not "save the planet-kill everyone on the road". Such statements and headlines are the signature of the stupid and ignorant..I mean yes, to your point, each driver would probably be fine but all things being equal, gasser civic driver has a higher likelihood of having his testicles shoved back into his body where of course they revert to being ovaries.
You just need and an ejecto seato, then the crumble zone is irrelevant.
Not answering your question because its intentionally irrelevent.And please let BobB (I mean batshitcrazy) answer the question.
Thats just it. The cars wont be identical when in 10 years youve added 2,000 lbs to 25% of them that used to be identical. Its very significsnt when studies showed when a car outweighed the other by 1,000 lbs the fatality rate soared by 47%.Make it two identical cars. I kind of thought that went without needing to be said.
These are peoples mothers, daughters, babies that are going to be killed.
What lack of conscience you must have to sit here trolling trying to hide this from the public. WTF is wrong with you? Is Joe Bidens schlong that deep in your throat you feel the need to do this?
You pretend to be smart I know what youre doing. Youre being intentionally ignorant and obtuse, introducing concrete wall collisions, just trying to muddy the waters.
Youre fucking irrelevent here dude. I provided the most credible references possible, this is physics on the 6th grade level.
Youre just proving what a waste of intelligent conversation engaging with a troll is.
"According to a key study published by Oxford called "Pounds That Kill," when the other vehicle involved in a crash is 1,000 pounds heavier, the likelihood of dying in that crash increases by 47%."
In case someone forgot the point here.
IIHS EXPERT:
"Less easily solved is the problem this extra weight poses when one of these extremely heavy EVs crashes into another, nonelectric car or SUV with a typical weight of 3,000-4,000 pounds. (A nonelectric pickup, typically weighing about 5,000 pounds, might fare a bit better.)
When two vehicles collide, the heavier vehicle pushes the lighter one backward, resulting in higher forces on the people in the lighter vehicle and lower forces on people in the heavier vehicle. That’s why we stipulate that our frontal crash test ratings — which are conducted against a fixed barrier and simulate a crash with an identically sized vehicle — can only be compared among vehicles of similar weight.
Over the years, we’ve conducted several demonstration crashes that paired larger vehicles with smaller ones to show the effect of size and weight on crashes. In two 2018 tests, one involving a midsize SUV and a small car and another involving a large car and a minicar, both the smaller vehicles performed poorly, despite good ratings in our tests.
.... their extra weight will afford them greater protection in a multivehicle crash. Unfortunately, given the way these vehicles are currently designed, this increased protection comes at the expense of people in other vehicles."
You prove that every time you post.Stupid can't be fixed.
Well, you keep driving that ICE car then.... ROFLMAOYou prove that every time you post.
Darwins been dead over 140 years. Are yoiu some kind of reincarnation nitwit? If so your past life was a small insect I wiped off the sole of my shoe.Well, you keep driving that ICE car then.... ROFLMAO
Darwin will be along soon enough.
Ill check your mama when shes done eating my shorts, smurph. Of course I know what it means.So you are too stupid to understand what it means.. Check.
Did your parents have any children that lived?
