Plum Crazy Rob
Yes to be clear, to run 100% Solar you have to disconnect Grid (breaker). Mine works great. Others not so much some sort of MPPT issue T B D. If you have any problems it's been proven wise to leave Grid on and put up with the "40w"
Some kind of loading snafu on Solar aircon app. Others have experienced this. See also this thread here. I'm on Android 13.
diysolarforum.com
![diysolarforum.com](https://www.mobile-solarpower.com/uploads/1/2/9/6/12964626/img-20190331-124124-456_1_orig.jpg)
Help me Install 3 EG4 Mini Split Solar Heat Pumps
THREAD INDEX: (Links Updated: 2/15/2024) This is a long Thread, So I have added this Index Note: Click the Post Number to Follow the link. The Topic discussion will follow from that Post TOOLS USED FOR DIY A/C INSTALLS Tools - 662 THE INSTALL General 1st 24k - 5 2nd 24k - 6 12k - 139 Nitrogen...
![diysolarforum.com](https://www.mobile-solarpower.com/uploads/1/2/9/6/12964626/final-favicon_orig.png)
