EG4 6000XP Released, ordered. Let's Go!
Question - Overloading the 6000xp when grid is connected.
The 6000xp will switch to grid bypass when overloaded.
The 6000xp will switch back to battery when load drops under inverter limit and/or 4 minutes (didn't test with stopwatch)
Wow, that's a nice feature! Really appreciate you testing it out.
Any possibility SS will send you a 2nd inverter to test in parallel? @Markus_EG4
Anyone with this unit running Solar Assistant? How does it compare to the online system? Wanted to see how to get data from inverter to Home Assistant, one way is SA, another would be a lux power module someone has written... If you use SA do you lose access to the cloud data?
I have one on order from Current Connected. I do plan to use Solar Assistant with it - I'll report back on how it goes.
I may be wrong but it appears that with the LuxPower units like this one and the 18kpv - that you might be able to use both SA and the EG4 monitoring system simultaneously. If so it should be interesting to compare the two as far as features and data...
FOR ALL MODULES, THE CALCULATIONS NEED TO BE PERFORMED OR VERIFIED BY USING A STRING CALCULATOR OR CONSULTING A PROFESSIONAL.
The inverter has two MPPT PV charging circuits. MPPT #1 and #2 will utilize up to 17 amps, which means two strings can be paralleled for any modules having less than 8.5A (Imp) rating.”
That makes it sound like 8.5a for each MPPT.
Do you know how much v
Each, according to the math.
Edit: actually I don't know. It could be either way.
what about the v
Per MPPT
Eachi
Agree with @timselectric . It's per MPPT. Also keep in mind that the voltage max is a hard stop - if you go over it you're at a high risk of damaging your inverter. The amp max, typically, is a soft stop. If you go over it the inverter will simply clip at it's max rating (or below). The manual on this inverter says 17a is nominal and do not exceed 25a. These are both per MPPT. I think you can likely expect clipping above 17a but I would definitely avoid exceeding 25a.
And finally, if you're close to the max on the voltage you need to do the calculations on temperature coefficient. In cold weather your voltage will increase. Run the numbers before you do the installation just to be sure. There's a good calculator -> here and all the information you need should be on the spec sheet of the panels.
so I have 12 50v 11a solar panels. So I can do 6 per series and x 2 mppt and it will bring me to 300v and 11a at each mppt. And is ok with the inverter? Sorry I’m new to this trying to get all 12 panels in one inverter to keep the cost low.
with the 6000xp connecting to EG4 LL V2 batteries are there any issues? Any firmware versions that need to be worried about?
So to be clear on first sentence in the manual. Both MPPTs could have different panels? When in parallel strings must be equal? Also maybe haven’t made it that far in the manual. My panel in my shop where I am installing is not N/G bonded. How would I set it up? Keep them separate or bond them and where? Thanks in advance!
correct, different panels
What's the downside and or problem with shading? I'm just trying to understand the problem it may cause. Pretty new to this. Or different panels for that matter.
With a Tigo
TS4-A-O​
Optimizer on each of the shaded panels you will get max output regardless of string layout. you can even monitor each panel output with the Tigo cloud connect module
Shading cuts power output. Try to string together only panels that share shading during the same time of day.
Ok I understand that, but does it have any adverse affects to AIO inverter? Does it reduce output of other panels when one is shaded? Thanks for your help. I have a SW 4024 at the cabin and I am liking the foot print and ease of installation of this unit.
With a Tigo
TS4-A-O​
Awesome, on top of that monitoring individual panel performance is nice. How does it communicate with the cloud? Saw on spec it says wireless but does it go through WiFi and what is range? My shop is a metal building and not good with WiFi transmission
it has an antenna that mounts on the roof and talks to the panels, the cloud connect has ethernet and wifi to connect to the web for monitoring from there.
You buy the Tigo Optimizers and The CCA and TAP.
Screenshot_20231012_221525_Edge.jpgScreenshot_20231012_221955_Edge.jpgScreenshot_20231012_223833_Edge.jpgScreenshot_20231003_223914_Edge.jpg
