timselectric
- Feb 5, 2022
- 19,821
19 months and counting.Are people still using growatts?
It was for about 6 months.Hmh...connect it to the grid and let's talk in a year...
Growatt sucks.
IP20 rated.Is the 6000XP outdoor rated like the 18KPV? If not, does it really need to be indoors or simply out of the weather (thinking leanto type structure)?
This would be to run most but not all of the circuits in my house through a 10 circuit transfer switch, and figure 3000w would be fine. Only potential loads which could max that would be kitchen appliances like the microwave, air fryer, etc as well as tools like the table saw, miter saw, etc and a mix of running different appliances at the same timeWhat loads are you running
Yes 3000W 120V on each line
Deciding between this or the EG4 6500EX. I don't need 240v, only 120V output. Would it be correct to assume that the 6500ex would be better for my application since the single line AC output on the new 6000XP would only be 3000W each line? I realize the idle consumption of the 6500ex would be higher, so that would be something to consider.
If you already have a Reliance TS, I’m sureThis would be to run most but not all of the circuits in my house through a 10 circuit transfer switch, and figure 3000w would be fine. Only potential loads which could max that would be kitchen appliances like the microwave, air fryer, etc as well as tools like the table saw, miter saw, etc and a mix of running different appliances at the same time
No.Can you do grid passthrough for 120V in (just L1 connected, and not an L2) to charge the battery bank when connected to shore power, and have the other leg of 240V run off of the battery?
When I heard you say 25 second surge in your video...I was like no way.The 18kpv has 5/10 minute surge ratings. Figured it was consistency across the product line. I was wrong to trust the documentation.
Pisses me off when spec sheets have errors. It's too common in the off-grid solar industry.
I looked through the 3 PDF documents for the EG4 6000XP but didn't see 'pure sine wave' anywhere. The spec sheet just says that THD < 3%. I'm just wondering what the output AC waveform looks like and if it would impact sensitive electronics.
240v generator is required.Had a read of the manual and it was not 100% clear to me.. Is it possible to charge the batteries off a 120v inverter generator, or does it need to be 240v and large enough to supply the load and charge the batteries? Would be ideal to be able to trickle charge the battery off a small generator when needed.
Not with 120v, https://diysolarforum.com/threads/testing-eg4-6000xp-aio-inverter.71312/post-905769Had a read of the manual and it was not 100% clear to me.. Is it possible to charge the batteries off a 120v inverter generator, or does it need to be 240v and large enough to supply the load and charge the batteries? Would be ideal to be able to trickle charge the battery off a small generator when needed.
Yes exactly, I need to test it out but it should be 6000W + 12,000W. How cool is that!Will mentioned something about using the 6000xp to supplement an 18k pv through the generator hook-up (starting at 6:03). So can you expand the capacity of your 18k with the 6000xp somehow? Anyone have some insight on this. I have an 18k, although it's not installed and I am debating about selling it and getting three 6000xp's instead; I don't need the grid interactive functions on the 18k and would like a bit more juice for those high demand days. Or maybe as Will suggests I can supplement the 18k with the 6000xp?
Test slightlyWill mentioned something about using the 6000xp to supplement an 18k pv through the generator hook-up (starting at 6:03). So can you expand the capacity of your 18k with the 6000xp somehow? Anyone have some insight on this. I have an 18k, although it's not installed and I am debating about selling it and getting three 6000xp's instead; I don't need the grid interactive functions on the 18k and would like a bit more juice for those high demand days. Or maybe as Will suggests I can supplement the 18k with the 6000xp?
No, during my testing...Generator needs to support entire load.Is this inverter capable of generator boost like a victron? Want to operate it in parallel with either my generator or my car’s V2L.
Will’s video seemed to imply it could but I couldn’t decipher this from the manual.
Sounds like a chargeverter is the way to go here.No, during my testing...Generator needs to support entire load.
The ChargeVerter is extremely useful.Sounds like a chargeverter is the way to go here.
And if you have multiple inverters running off the same 48v pack, it can charge it up for all of them with no weirdness.The ChargeVerter is extremely useful.
I can run my smaller 3.2K 120v inverter generator (open frame) and Set the ChargeVerter between 30-50 amps.
