jmjack
Need More Sun
Wow, that's a nice feature! Really appreciate you testing it out.Question - Overloading the 6000xp when grid is connected.
The 6000xp will switch to grid bypass when overloaded.
The 6000xp will switch back to battery when load drops under inverter limit and/or 4 minutes (didn't test with stopwatch)
Any possibility SS will send you a 2nd inverter to test in parallel? @Markus_EG4
