I know this was started with the server rack battery in mind, so hope it's ok that I'm discussing the standard 25.6V 150AH Cloud Energy. I could not find out anything about this brand via the usual search methods, so I figure every little bit helps. I did receive the spec sheet for the CL24-150A, and there are definitely some conflicts between all the different sources - Amazon listing, Cloud Energy web site, and the spec sheet. For example, Amazon shows the weight as 55.12 pounds, spec sheet says 62.7 pounds. The web site lists a 'Continuous discharge current' of 150A, with a 'Allowed Max. discharge current' of 300A (for 100ms). Whereas, the spec sheet only lists a 'Max continuous discharge current' of 100A, with a remark of '5 seconds'. If it's continuous, how is there a time limit? They all agree on a 100A BMS. The spec sheet does mention 'low temperature protection' as a feature of the BMS - not mentioned anywhere else. But strangely, the remark is '-20C'. ?? In the charging section, it lists 0C to 45C as the allowable range during charging. Spec sheet is clearly wrong on the rated power, showing 38400WH instead of 3840WH. They have no idea how many batteries you can combine. Amazon says 4P2S (sounds right), web site says 2S6P, and the spec sheet says 8S1P (wouldn't that be the same as just 8S, not to mention 204.8V?) !
If you look in their online shop at both their 48V batteries, the title of the page says 12V 300AH, while the text describes a 24V 100AH. Clearly they have some bugs to work out with their specs and pages!
All that said, it is still very tempting due to the price of only $0.22 per WH.
Aaron
