Hi this is my first post here
We got our hands on 72 cells Sonnenschein a602/1250 gel batteries with a total capacity of 180 kWh. The cells are 2v each and the plan is to make 3 separate 48v 24s packs that are then connected to the same inverter (haven’t found one yet). My biggest concern having only worked with LFP and li-ion batteries before is what, if any bms is required. Our goal is to be able to pull 100kW of continuous power from the pack. Anyone done a project like this before? The plan is to start by parallel connect them all to make sure the soc is well balanced before we do any series connection. Any ideas on what equipment we should use to test the capacity of the cells?
