apw63
Hello,
I just purchased and installed 2 new SOK 12v 100Ah heated LiFePo4 batteries. Batteries where purchased from @HighTechLab. My current system was installed by Lance and is by Go Power, PWM 30 Solar controller charger, 2 190 watt panels, 1500 watt inverter & battery monitor GP-BMK-50. The batteries are mounted one on each side of the trailer. They are connected in parallel with 2/0 welding cable. The cable from the inverter to the batteries is also 2/0 welding cable.
What I'm seeing during discharge is unequal discharge rates. When I'm using the inverter to draw a load I'm seeing on battery #1 -35 amps 13.07v and on battery #2 -28 amps 13.04v draw. The batteries show different SOC after inverter usage, battery #1 95%, battery #2 97%. This makes sense to me because one battery has a greater draw. I'm using a drip coffee maker as a load. After discharge is over and the panels start to deliver amps. The charge rates are are approximately the same + ~6 amps ~13.42v on both batteries. When i use my volt meter on the batteries the meter shows equal volts on each battery. I don't have a clamp on amp meter, maybe I should get?
Is this normal discharge behavior? Is this something I need to worry about? I'm new to LiFePo4 batteries. If I left out any information that would be helpful please let me know.
Thank you for any help/advice/experience
Andy
Andy
