Steve Dally
- May 10, 2021
- 16
So I'm reconfiguring my battery to build it up as a 2p4s 560ah total... I will have loads of up to nearly 200 amps (I'm using the Radio B tech 4s 200 amp BMS), but I'm just now realizing/suspecting that the standard bus bars that come with the battery cells (ninthcit 280 ah, in my case) are not up to the task. Can I double up on the bus bars, using two of them for each of the connections, or do I need to get bars properly sized for my application? I suspect the answer to this is that I need to upgrade to a properly sized bus bar, so my next question is where do I find them? I have seen some DIY videos, using 1/8" 110 copper bar, but I don't have a drill press, making the slotted holes a little difficult... any insight here?
Thanks in advance
Thanks in advance
