That would be interesting to see... Is there evidence or documentation that shows that hardware is different in vehicles in EU/Japan and US market? Is it only configuration? Maybe one day the dealer (or a cleaver guy with an ODBII dongle) can do something about it...If I replace 120V V2L ICCU of my USA IONIQ5 to an ICCU for South Korea IONIQ5, will I get 240V V2L?
Thanks and Happy Father's Day
This is what I'm doing too -- going to use a Victron Multiplus-II 2 x 120V... which includes a 50A 240V transfer switch.
With the EU power available in NA, no need for a Quazar or dcbel for occasional outages. It would just fit perfectly like a gas generator...
I don't think one should connect a V2L in a config where inverter thinks it is connected to grid. Since it is possible the inverter will attempt to export before it detects invalid grid.HOWEVER, it does NOT work with the ESS assistant if you have that configured in your Multiplus system.
@drlanford,Hey Winnie. Just wanted to pop in here and let you know the Multiplus works great with solar and with using the EV6 as a viable 120V source, provided the proper current limit is set.
I just got this up and running yesterday. Was able to export about 32A at just under 52V. When I bumped the Chargeverter up to 34A, the car tripped off the output. At some point I’m going to try to parallel the two 120V outputs to see if I can get over 3k. I’ll likely test just loading the exterior V2L output with the Chargeverter and then load the interior V2L with another load to see if I can get a combined output over the rated 1800w. I’m not convinced those two outputs aren’t the same output.@drlanford,
Are you just connecting the V2L to the AC input on Multiplus and limiting to 15a
draw? Never thought about the power assist for larger loads until it was stated above.
You can do this yourself but trustworthy folks on Ioniq5 forum say it's on the same 1800W inverter in the car, only (maybe) separately fused. Many people before you have smoked on this hopiumAt some point I’m going to try to parallel the two 120V outputs to see if I can get over 3k.
So you didn’t use V2L to the AC Input of Victron, only V2L to chargeverter to batteries?I just got this up and running yesterday. Was able to export about 32A at just under 52V. When I bumped the Chargeverter up to 34A, the car tripped off the output. At some point I’m going to try to parallel the two 120V outputs to see if I can get over 3k. I’ll likely test just loading the exterior V2L output with the Chargeverter and then load the interior V2L with another load to see if I can get a combined output over the rated 1800w. I’m not convinced those two outputs aren’t the same output.
I used to have an I5 until it was totalled.
The power of the two outlets are shared.
You can use the Korean plug to get power from the charge port. It uses the onboard inverter, so you get the right power for your country. The plug has the circuits to tell the inverter to discharge, not charge. I forgot if you can get 120v, or if it only gives 240v (level 2 charger).
I agree...but I did it anyway with export turned off and "grid setpoint" set to 10W. In that configuration, I've never seen it export. However, that doesn't mean it hasn't for a very short period of time like when an A/C compressor kicks off before the voltages stabilize again.I don't think one should connect a V2L in a config where inverter thinks it is connected to grid. Since it is possible the inverter will attempt to export before it detects invalid grid.
Yes the Chargeverter config is something I have been interested in to guard against this. In my particular case I would combine it with microinverter AC coupling and that will definitely not be compatible with syncing in AC power from V2L
I recently checked and LOM is already set to Type B so that rules out that potential solution. I must keep LOM detection on as I am typically connected to the grid. I may look into an anti-islanding device so I don't have to reconfigure the Multiplus every time I want to use the EV6 or a small genny as a power source for the Multiplus, but those are quite expensive.
Source?looks like the kia ev9 (same platform) may be able to send 240V@15A split phase
