Northernchateau
I received 8pc PWOD CATL 3.2V 310Ah grade A lifepo4 batteries from Aliexpress a few days ago.
I placed the order April 13th. They showed up 1 month late but they got here.
From the pics below you can see the box/packaging was in great shape.
The batteries were packed individually. and I have no complaints there.
I inspected each battery and all the cases are very good with no scratches or blems.
Both sides are flat and all batteries tested 3.28 volts.
As you can see these have threaded stud posts vs a tapped hole that I have seen on others.
I presently have 1 battery top balacing so I can load test it to see if I actually received a 310 ah battery and will post a report when I am done.
