Do you believe that a majestic wizard is waiting at the assembly line for over 1 month just to pick over 11 days the 32 cells for 1 order out of 1 million produced cells in that 1 months ?How are you so sure about the grade B?
Luyuan is one of the few I know who are actually selling genuine EVE cells with the reports included.
These are (Should) be the cells with the double M6 terminal (Since thats the only terminal EVE directly provides)
While I do agree with your post about the quality control situations, i'm curious how you can assure by just a single screenshot they are 100% fake cells.
Did I talk about fake cells or B grade, as they are called by EVE for those who did not pass the automotive grade test.Have you got also a test report about the circumstance during the test ?
These are grade b cells for sure cause they spread all across the board but do not reach the level of an A grade cell.
You need to know at what temperature they had been measured cause if they test that in a well heated room or a closed room that is only charging and discharging you might get 28°C which will deliver 10 Ah more compared to a 20°C room you might test them.
The capacity depends on room temperature. The Eve LF280K looses about 4,6% from 25°C to 10°C so about 14 Ah and roughly 10% from 10°C to 0°C.
If you have a used or grade b cell how would you test that if you wanna sell it for highest price?
just at more than 25°C cause above that the capacity does not raise anymore.
So a used battery can be tested with the capacity of a brand new one if you simply preheat the battery cause EVE has a lower temperature for capacity measuring.
This is another example for fake cell deals, which means a used one or a grade b cell that did not pass.
The disussion was about grade a cell and I said that these must be grade B cells based on the EVE standards where every cell is now marked as B that does not passed the automotive test required.Please see My Response linked Above.
2) Not all Cells within a Production Batch make it to Grade-A and that is typical of EVERY Manufacturer and NOT Unique to EVE, CATL, or Lishen etc.
3) Optimal Voltage & IR are Measured at Consistent Lab Baselines which IS 25C temp. 10C or 30C Temp of course affects the overall "Working Voltage Capacity"
4) Cells are Measured @ Working Voltage (3.000-3.400) and NOT Gross Overall Voltage of 2.500-3.650.
I have DB / Sheets with 800 Cells+ Matched Cells Shipped in one package. IF they are out of order or some sequence missing due to "fail" for a number of reasons they are removed by EVE & shipped as Bulk for less without Enhanced Terminals. (This is New) and now are also marked accrodinglingly to avoid prevent Wholesalers/Brokers from harming the company & taking advantage of clients/customers.
YES, some companies could better SORT cells to match exact Capacity AH but IF they fall within the Allowable & Acceptable "A-Series" specifications for Working Voltages they will perform within those specs. There are ALWAYS occasional Cell Drops within a Production Batch and they are omitted from the grade tables.
NB: Several Vendors takes from mixed batches or short batches with tests and they can be quite disparate, That is also a "Red Flag" which should be paid attention to.
IE I have Batteries that are Bulk & Matched from "Other" (not good) vendors that failed, YET they remain within 0.010V of each other when properly Managed & Configured, while the A-Cell Packs remain within 0.007 to 0.009 IR across the pack itself.
EVEN My Used EV LFP Cells (2 packs of 174AH) stay within 0.010Vpc within each pack.
I even use JKBMS' (B2A24S15P) all across in Parallel and ALL Packs are within 100% Spec.
I See temp swings here from -35C in Winter to +40C in Summer.
--> My Powerhouse is Highly Insulated and Heated to 15C in Winter, no Cooling is required in Summer as it maintains a MAX of 27C without active cooling due to Construction Method. Highly Insulated (XPS-2 foam) with 5"/12.7cm with thermally broken walls, Frost Protected Slab Foundation with 2"/5.08cm HD-FPSF Foam and a Roof insulated with 6"/15.2cm of PolyIso Insulation, also Thermally Broken from the exterior. Air Heated ATM but plumbed for Radiant Heating as well. This Building is also my Pump House (280'/85.3m) Well, Pump & 50Gal-US/190L Pressure tank that feeds the House.
BTW: Not only with my experiences through here. I was working very hard to set up a Battery Distributorship to leave to my children selling parts & Completed High-Quality batteries here in Canada (Certified & Tagged accordingly - what a freakin nightmare). Sadly my "time ran out" and only one daughter had interest but could not carry it through... Later Regrets for her, 1 of 5, 3 which are surviving..
Steve
PS Look at my Signature for Links.
I have dealt with Grey Market, Clone Market, for Computer Technologies since 1989 as a Systems Engineer & Designer for the IT Sector, Including within the NATO Military Tech Work and & Federal Government Systems. So it is an old "hack" dealing with Primary Manufacturers, & Beyond from various regions globally related to that sector. You think "Auto" has been a Mine Field, you have no clue my friend. Control Data, IBM & Cray MainFrame Computer Tech to Compaq, HP, Sun, DEC to Alpha Multi-Core Super Servers (+) and Comms /Networking tech you cannot even imagine. I am STILL under Federal & International Security Restrictions (30 yr National Sec) from Travel etc due to what's inside my Eidetic Memory or Sharing detailed info about such. I retired as 1 of 7 IT Core Engineers for DND.I had been working in the automobile industry for a few year, no, better decades and the supply chain so I am a bit familiar with topic and how to deal with the non a grade parts no car maker loves to see on the grey market cause the dealer and repair shops and the reputation of the brand can rely on that.
Well, wasn't this topic just about WHY these cells are NOT GRADE A cells ?I have dealt with Grey Market, Clone Market, for Computer Technologies since 1989 as a Systems Engineer & Designer for the IT Sector, Including within the NATO Military Tech Work and & Federal Government Systems. So it is an old "hack" dealing with Primary Manufacturers, & Beyond from various regions globally related to that sector. You think "Auto" has been a Mine Field, you have no clue my friend. Control Data, IBM & Cray MainFrame Computer Tech to Compaq, HP, Sun, DEC to Alpha Multi-Core Super Servers (+) and Comms /Networking tech you cannot even imagine. I am STILL under Federal & International Security Restrictions (30 yr National Sec) from Travel etc due to what's inside my Eidetic Memory or Sharing detailed info about such. I retired as 1 of 7 IT Core Engineers for DND.
If you are only just figuring it out, the Battery Marketspace & Manufacturing is Evolving Globally Exponentially as one of the Fastest Industrial Sectors EVER ! This not only applies to China but EU & Beyond with the USA far behind and losing ground thanks to the Anti-Change denialists & regressive's. Just LOOK at EU and the Vast Expansion & Growth coming from "everywhere" and Domestically.
The US can thank Big Fossil (Oil/Gas/Coal and their Luddite Profiteers who have always wanted to keep "Status Quo Profit Control" who have actively been the worst Criminals against ALL of Humanity and still continue to push. THEY are also guilty of "Protecting" China's EV & Related Green-Tech growth by effectively squelching ALL Western Development to their "Desires & World Dominating/Control Profit Core".
What do you think they spent their subsidies on ?
Why do you think Russia's 47% Of Petro By-Products (not just gas/oil) affected the "Failed Globalized Market " ?
- which is hitting Everyone Everywhere regardless of Mediaganda hooey ? IT IS ALSO Hitting the Tech we are trying to outplace the Old with, food, neds and everything included.
Tsk Tsk Tsk, the Landscape Picture, not just the "Focussed Portrait" presented by Media.
As a German, You Have to appreciate Cause & Impact & Consequences.
END of this Thread for me. (no more responses)
Good Luck & Have fun with the remainder of this life.
Steve
I mean, that's probably not what they are doing? Because as you pointed out, that's clearly not realistic. Your posts are really hard to follow, BTW.Why would EVE pick 32 single cells over 1 months out of their production line to ship them to a customer as their personal selection?
The problem with this is that EVE is not set up to sell to customers who only want lower volumes of cells. Someone here bought from EVE directly and their packaging is garbage for smaller orders, the cells were badly damaged. I dont know if EVE ever made it right for them.And if someone want Grade A cells then the best spot to go is the manufacturer of these cells. You will have to pay but you will also get something rewarding or at least peace of mind.
Luyuan buys Direct in batches of 1000+. Grade A come off the EVE Test Racks with reports, 99% off the test rack are A. Those which are not are tagged & indicated as B. B's have Posts welded to them, while the A's have the new style since they started that. Anything that EVE determines to be C are remarked and sent to brokers who offload them to whatever vendor for CHEAP.I mean, that's probably not what they are doing? Because as you pointed out, that's clearly not realistic. Your posts are really hard to follow, BTW.
I don't know exactly how Luyuan gets their batteries, but I could easily see a sequence of events where Luyuan ends up with legitimate grade A cells....
Let us imagine a scenario (making up numbers for illustrative purposes):
- EVE factory can produce (f.ex) 10,000 cells a week, but there will be a percentage (let's say 1-2%) of those that don't meet EV Grade/Grade A spec
- EVE is building batteries to supply their clients, they arent building them to just warehouse. So we could also assume that EVE has clients that have firm orders / will take delivery of the number of cells EVE predicts it will produce as EV grade. So at a max "fail" rate of 2% (per our assumption above) thats 200 cells out of 10,000 that won't be to spec, so we can assume EVE has, in the best case, firm orders for at most, 9800 cells.
I think we can agree that both of those points are fairly reasonable?
So then the next logical step is....
This week EVE has a great production run and the fail rate is only 0.5%. That means they can satisfy the 9,800 cells to their firm order clients, but now they have another 150 cells that no-one ordered or wanted - Luyuan may have a contract to buy these, and the volumes could be sufficient to satisfy Luyuans customer demand.
Right? Like I get what you are saying, but we have evidence in other threads here, that Luyuan is selling Grade A cells.
I think you're going to have to bring more to the table than "well the cells are from different batches" if you want to convince people against existing evidence that Luyuan cells are not Grade A, because as I illustrated above, that's hardly conclusive.
We have gotten 32 cells from EVE Alibaba shop and they shipped them according to international rules pretty well packaged as all the others we had gotten before from china. They had been using the international shipping boxes and used the right declarations.The problem with this is that EVE is not set up to sell to customers who only want lower volumes of cells. Someone here bought from EVE directly and their packaging is garbage for smaller orders, the cells were badly damaged. I dont know if EVE ever made it right for them.
Nah man, EVE sent with shitty packaging, they shouldn't have been so beat up. I got boxes from China with batteries from Docan and one of them was beat to shit and the batteries inside were 100% fine. Maybe if you had seen the thread you wouldn't be making excuses for them.Damages during shipping happen from time to time.
Yeah, because you bought from EVE directly. That doesn't mean anything with regards to Luyuan, per my previous post.All these cells arrived as a batch from the assembly line produced on the same day, not from several days over 1 month.
