David glenn
I’m currently using 48 V 10 amp solar panels in my 12 V system do I need to change to 24,36 or 48 V to achieve the full potential of the solar panels wattage?
No, any reasonable MPPT SCC will do the voltage conversion just fine. Its pretty much the whole point with MPPT SCCs.I’m currently using 48 V 10 amp solar panels in my 12 V system do I need to change to 24,36 or 48 V to achieve the full potential of the solar panels wattage?
Am I getting the full 370w at 12v. This setup is in my beach trailer and I’m wanting to maximize my charging for A/C, A/C refrigerator and other A\C appliances to minimize my possible generator usageNo, any reasonable MPPT SCC will do the voltage conversion just fine. Its pretty much the whole point with MPPT SCCs.
If you post your panels specs and SCC model/specs, we can see if its compatible and help you optimize it.
BTW I’m replying for my brotherAm I getting the full 370w at 12v. This setup is in my beach trailer and I’m wanting to maximize my charging for A/C, A/C refrigerator and other A\C appliances to minimize my possible generator usage
I do not think that is an MPPT charge controller. Someone else here commonly says that if it has a USB port, its PWM.The controller pictured charges up to 14.4 V and up to 35 to 40 A I believe that’s only five or 600 watts to my battery.
You’re correct, my mistake, PWTI do not think that is an MPPT charge controller. Someone else here commonly says that if it has a USB port, its PWM.
I'm not an MPPT snob but they are often necessary for big panels/arrays.
Can you post the specs of the SCC? And how are your (2?) panels connected, parallel or series? (i will assume parallel since series voltage would certainly smoke that SCC).
How many amps is that SCC rated for?
370W x 2 / 14.4V = 51A to the battery(s).
Need SCC and array info.
What battery(s)? How many watt hours and what chemistry?Thoughts???
How many watt hours is this daily? A/C as in air conditioner? How big, how many hours?charging for A/C, A/C refrigerator and other A\C appliances to minimize my possible generator usage
Max PV Open Circuit Voltage | 100V |
Only when in reverse! I was thinking liftoff and stall speeds...Talk about downforce lol
They rotate and adjust in angle. They rotate 180° from pic and are secured during travelHave you tried driving the trunk with the panels like that , like a big sail at the back ?
370 x 4 parallelI do not think that is an MPPT charge controller. Someone else here commonly says that if it has a USB port, its PWM.
Marr panels rotate 360° and tilt to maximize inputHave you tried driving the trunk with the panels like that , like a big sail at the back ?
Thats got to be close to 40A. The MC4 connectors and 10AWG panel wires are good to about 30A.370 x 4 parallel
