42OhmsPA
What's in a title?
Edit 6-26-24 6MWh
Edit 5-31-24 5MWh
Edit 4-12-24 4,000 kWh
Edit 3-23 Current Settings.
Edit 3-4-24 3MWh
diysolarforum.com
Edit 1-2-24 2MWh AC output, close to 2MWh solar.
https://diysolarforum.com/threads/1mwh-srne-asf48100u200-h-10kw.67809/post-966398
Edit 11-13-23 - darned close to 1Mwh of solar with no equipment issues. https://diysolarforum.com/threads/srne-asf48100u200-h-10kw.67809/post-913538
End edit.
This will be an ongoing thread with feedback on this unit. It will be a few days (week) before I get everything hooked up.
If anyone wants me to test anything before or after connecting everything please let me know.
I ordered direct from SRNE through Alibaba on August 8th, it arrived yesterday. Just under $1400 all in. This will most likely be another step before I upgrade to something even bigger / "Tier 1".
Currently running a TP6048 with ~5.6kw PV and ~22kwh of battery.
Major loads consist of 1hp well pump ~40a inrush per leg and 1.5hp belt drive compressor along with your typical household items except the dryer and oven. (more details in the introductory thread I've been meaning to make...)
I'll be adding another 3.6kw of ground mount PV and at least another 11kwh of Lifepo4. The dryer will also be added to the loads.
My initial impressions, in comparison to my TP6048.
It's much lighter! I don't know how this HF venture will pan out but I'll be sure to let you know.
The build quality is much better. It feels much more robust, the shell is thicker and the paint is much better.
There will be a lot more room to wire everything up and it seems like it will be easier. I'm using a trough this time around, I completely overlooked the oval PV opening, I'll figure out how to get EMT to it nicely.
Enough rambling on to what everyone wants, photos.
2nd edit - removing the ?? symbols from the title since they are annoying me viewing new threads. I still give it ?? ?? and ? ? ? ? ?
Edit 5-31-24 5MWh
Edit 3-4-24 3MWh
![diysolarforum.com](https://www.mobile-solarpower.com/uploads/1/2/9/6/12964626/img-20190331-124124-456_1_orig.jpg)
5 MWh SRNE ASF48100U200-H 10kw.
Finally hit float today after however many months it's been. Am also very close to 1mw. Has been an incredible and flawless machine that suits my use case perfectly
![diysolarforum.com](https://www.mobile-solarpower.com/uploads/1/2/9/6/12964626/final-favicon_orig.png)
End edit.
