Adam De Lay
Solar Wizard
Give Current Connected a call. They should be able to help you out.No idea. Anyone?
No. The 4S block is 100ah and the battery rack has up to 600ah of power.The EG4 will have 4/0 cables from the server rack w 4 EG4 Lifepower4s to the busbars.
The BBs are wired with 2/0 cables to the bus bar from each 4s block
Is that going to be an issue as well?
You can. I can’t remember, do the battery’s have multiple positive and negative terminals on each battery? I might do it as long as it’s temporary. Keep an eye out for hot terminals as that would show a poor connection.Also, can I daisy chain the EG4 batteries with the supplied cables in parallel to the terminals and then just run 4/0 cables from the end pos and opposite end neg to my system? This would be temp until my rack arrives. Or must I use busbars?
Yes. It’s called “open loop communication”. I’m guessing that’s how your BB batteries are running right now. In fact since your mixing batteries, you’ll provably always have to run that way.Also, can the batteries be used without the RS485 cables connecting them? Mine are on order but don't have them yet
Yeah, I don’t know of any reason you couldn’t just use that as a stand alone interface to the batteries.Thanks! Can I use Rs485 cables to the EG4 communication hub so I can see the battery status but not hook the hub up to the Victron?
The BB set and the EG4 set should have the same kwh so I should be able to switch one off to modify or repair while the other one runs fine.Seems like that should give you enough overhead if you had to run solely off the server rack if you had to perform maintenance on the BB batteries.
The autotransformer is interesting. Need to calculate the max load, that may be an easier solution than a second Quattro.I just saw your post. You also have the option of purchasing a Victron 120V-to-240v transformer (https://signaturesolar.com/victron-autotransformer-120-240v-100a/) instead of purchasing another Victron Inverter for your 240V loads. I see you have a Victron MPPT fed by your 2KW solar panels. I would look at the charging data and see how much KW is "really" being provided by your panels, since you just added another 20KWH of storage to your system. I do recommend to purchase the EG4 hub and integrate it into the Victron setup. I have EG4 V1 batteries integrated into my Victron setup and cannot help you with the integration however, I heard that hub suppose to provide the similar capability. I would also connect your EG4 batteries to a laptop so you can monitor them.
Is the ground not currently connected? The current setup w the BBs and Victron was all there before I arrived. I'm just adding the EG4s for now.Don't forget to connect the ground for the Quattro and the charge controller. Would also be good idea to add some kind of cover over that positive busbar even if it is just some clear plastic offset from the busbar.
Also, how did you attach so many lugs to that smartshunt? did you have to remove the washer and lock washer?
If you read back I am about to hook it up but in the photo the EG4s aren't hooked up yet.Where is the negative of those Lifepower4 batteries going? It should be to that smart shunt but I don't see it.
