InMyImage
- Nov 17, 2020
- 146
Looks like the bad experiences with welded studs has bit again… My Lishen 270ah’s came with welded studs from the “group buy” organized by “he whose name cannot be spoken”… they were supposed to be M8 but only ended up being M6 and I’ve seen some comments indicating that they aren’t even quite M6.
Anyhow, these studs threads suck, several came out in nice spirals as I was taking a pack apart and every single stud has some amount of damage so I’m going to have to rethread them all of them. Any advice on whether I should try M6 or just drop to M5.5 or even M5. It’s a mobile install in a fifth wheel trailer so I’d prefer to leave them as big as possible.
Before anyone asks, they were torqued, just hand tightened with a ratchet enough to be snug because I still haven’t actually finished the system and figured out the final system organization. Was working on trying to parallel balance the pack again and this happened when disassembling the pack. Afraid to disassemble the other pack until I have the die in hand and know it works with the studs on the other pack or if I need to cut these damned terminal studs off and get back to the original terminal.
Thanks
Thanks
