Alkaline
Solar Wizard
Lots of threads with issues with inverter comms and batteries, Almost seems like it would be better not to setup communication? Hakuna-Matata?
What about extended vacations away from home? Do you trust your system to take care of itself while you are away?Lots of threads with issues with inverter comms and batteries, Almost seems like it would be better not to setup communication? Hakuna-Matata?
I would trust the BMS to protect the battery, I would not trust the inverter to fix issues that the BMS could not do better.What about extended vacations away from home? Do you trust your system to take care of itself while you are away?
I leave my Grid tie, no battery system alone all the time, but I always have a nagging doubt something may go wrong with my battery connected system I built myself, if left for days on end to just do its thing. That's why I am looking forward to getting comms working, so the Inverter has more control of the complete system, and its settings will dictate what happens.
Am I being paranoid? Or is that a valid concern? What do you guys do if you leave home for two weeks or more?
Increase in complexity, increase in failure points.Lots of threads with issues with inverter comms and batteries, Almost seems like it would be better not to setup communication? Hakuna-Matata?
Just because you are paranoid does not mean Murphy is not lurking in the shadows. The two most important failsafe settings are Low Voltage Cutoff and High voltage setting. Communications can fail but if those settings are in the inverter and BMS you should be safe.Am I being paranoid?
I deal with this on a daily basis.
Thanks Joe. I'm not worried about "they". I am worried about "Murphy" and "Me"?I leave my system for more than a month at a time. Yes, I trust a properly designed and implemented system.
I also ignore it when I’m home, no difference.
I think you’re being paranoid. But then again, “they” may be out to get you. ?
Given how much trouble people ~seem~ to be having getting and keeping today's batteries working with today's inverters it seems foolish to assume you'd stand a chance of getting your 10 year old batteries to talk but more importantly work with you new inverter.
