Hey, about three or four days ago a 200amp T-class fuse blew on the connection between my 16s 280ah pack and the bus bar. I figured the headroom on my BMS was too high 18000 and the charge control amperage was too high 80Amp on each controller (split phase).
I ordered a replacement (coming tomorrow).
Just now I was doing some BMS work on the fuseless pack (increasing the fet opening time) when both inverters just shut down, restarted and showed the error for ‘no battery’. The second pack was not charging (as I heard no fet/relay noise), was fully charged and balancing. The inverters were calm and quiet as no major loads were running…
I checked the 2nd packs 200amp fuse and it has blown!
What could be the issue? Do I need to upgrade to 250amps? Could I have a short? I have no idea how to troubleshoot….
