cypher2001
- Jul 20, 2020
- 56
Just looking for everyones best ideas to compress cells. I know Will used pipe clamps. Is that still the best method?
No, I do not see that specd in the spec sheet.Do you have a compression force spec for the cells? If not, ballpark 15 in-lb. Which is a not much.
(see photo)
What happens if a BMS fails and one or more cells are overcharged like this? The main reason I ask if I am putting together a pack and as a newbie, am a little concerned that with this waterproof enclosure and the fit extremely tightly in the case (edge to edge exactly when closed (see pic) I want to make sure I'm not making a possible bomb with this setup when the case is closed if there was an unexpected issue with swelling.
I am not sure what the material is, this is the "pegboard" material they sell at the hardware store (I just had some). The idea is that in the remote possibility that the plastic wrapping got damage the Al casings would not connect (as I think it is possible the casing is one of the battery terminals).Well done, I like this. What is that between the cells? Looks like masonite maybe
