brandnewb
Going for serious. starting as newb
come again Gary? was the calculation incorrect? ignoring the garbage in garbage out for a moment.
ok bro, I have already a shipment of large steel disks arriving at your workplace in about 44 minutes.There is plasma cutter, and also water jet.
I tend to cut large thick steel with oxy-acetylene cutting torch. Only steel, not cast iron, because carbon content fuels the cut.
Angle grinder? Are you saying you cut a radius with that? In something like 1/8" steel?
I could imagine straight cuts with a saw and rounding off with a grinder.
I have used reciprocating saw for curves, don't like using it much.
Band saw with large enough throat would be reasonable, but limited in radius by kerf width and blade width.
That disk will be strong in compression and very strong in tension, not so much in torsion.
Gussets to make 3-D structure would fix that. Or does your planned assembly not apply torsion to it?
the above image was not so helpful as the resolution in time was set too low. But I was rather in shock and a little panicking to be honest as I was down on the grass underneath a spinning turbine. I just did not think to take the time to set things a little more appropriate.I went to the extra trouble to make sure I can get a clear shot of the oscope.
now drink this in!!!
It going to be brutal!!
