Hey Everybody! Hope you y'all are doing well! I'm struggling on a few things here and would appreciate any help as a newbie and math challenged individual.
Appreciate all the support comments and suggestions and help getting through this project! Still so much to learn and so little time. Thank you all!
- SOLAR PANELS: If I have 3 x 375watt panels that have a 48v voc and 9.96amp output, it looks like I may not need all three panels for my 2200 watt hours per day 188ah requirements? With my calculations I would need 675watts of solar panels. Do you think I should mount all 3 of the 375 watt panels? The panels are big and mounting 2 on the RV roof is doable but the third would have to be mounted on a rack. My battery bank is 4 x 6v GC Trojan t105s at 450ah wiring for 12v.
- MOUNTING: Being in Southern California do I need to mount them so they can be tilted to max the exposure?
- WIRING SERIES OR PARALLEL OR? Which way to wire the panels series or parallel or series/parallel? Is it correct, series will increase the volts exponentially, which will increase the size required for the MPPT?
- SHADE ISSUES? Should I consider shade for series vs parallel? Not sure how often one of the panels would be shaded. But I imagine if parking somewhere hot we would look for shade. I understand in series that the panel in the shade negatively effects all the panels output. Also wiring needs to be increased for parallel.
- INVERTER; What size inverter? Does this go by the device that pulls the most watts on startup and then the top load of all the items being turned on at once?
- CONTROLLER? I suppose the MPPT controller the way to go? If so what size? It depends on the panels being wired series or parallel?
- Wiring fuses circuit breakers (haven't really researched this much yet) Any suggestions?
- Any brand suggestions for the above?
