shavermcspud
- Mar 12, 2020
- 579
Hi all
I purchased the bellow unit two days ago and it doesn't appear to function correctly, when switching priority to solar only it goes straight to battery mode, the only way I can get it to use any PV power is to switch the inverter off on the main side power button and it starts to charge the batteries.
Firstly the company are saying it needs new firmware, but they don't know where I should get it from, im guessing its similar to an Axpert pip unit, ive checked the serial number and found a thread which shows this to be a genuine unit but rebaged, but not sure what or where to get the firmware from.
Then the company stated it must be an issue with my PV units, but if i connect my old SCC everything works fine.
Iconica 3000W 24V hybrid pure sine wave inverter with 40A MPPT solar controller and 25A mains charger
Any ideas on firmware download locations or even what model this is based on?
Thank you.
Thank you.
