Trygves
XW+ 6848
i did full reset and reprogrammed al parameters into the Inverter. I still do not have the green LED telling me that AC grid is ok and usable. No green LED at all.
Please note that on the chart above the AC 1 235.5 Volt - the programming for AC 1 says High Volt Disconnect is 133 Volt and should that be 240.0 Volt or so? Low Volt disconnect is programed to 108 Volt - should that be 220 Volt or so? All based on what I read above in the chart.
Also if I have only one Inverter should Multi-Unit Configuration be "Single Phase Master" or something like Split Phase Master?
