I’m confused. I have an XW Pro that I am trying to figure out how to use and get the most out of it. .
I can’t sell to the grid in my location it's not allowed and at this point I’m not intending to go off grid.
The main function of the system I am assembling is to backup a couple of freezers and a couple of fridges and a small AC if I am away in the summer.
That is the one thing it must do reliably. I am going to put those loads on a critical load panel and take advantage of the internal transfer switch . I am ordering a full size PDP with a bypass breaker for the bypass functionality and the possibility of adding a second inverter in the future. I think I have that portion of my problem sorted out. But if it sounds like I don't please let me know.
I also have a large, separate air conditioning load where I am assembling this system. When I am home I would like to feed this load from the PV’s through the inverter for about 4 hours a day during peak sun and peak outside temperature to lower my electric bill.
I am not certain how to wire that in to this system? I need that AC to run from the grid power most of the time. It pulls 4kw when it is hot out and it runs at an 80% duty cycle when temperatures reach110 degrees f.. Had a lot of those hot days this summer. My neighbors and I power bills have been quite a bit higher due to surcharges this summer.
To include the ability to run this load off my system do I need a manual transfer switch?, where I turn on the bypass breaker on in the XW PDP to keep the critical circuits panel heated up, then use a manual transfer switch to switch the AC off from grid power to a separate circuit from the AC side of the XW? Or is there a better way?
The one inverter I presently own doesn’t have enough capacity to reliably run both the backed up refrigeration loads and the large AC load at the same time. It’s one or the other. Because of that I don't think I can feed the large AC load off the critical load panel.
I’m planning my electrical panels,wire runs, and conduit runs right now and this issue has me at a standstill.
I have read the manual a few times and parts of it several times. I don’t really grasp Grid Support mode and Peak Load Shaving. It sounds good but without a second inverter I don’t think I have the capacity to power the combined loads of the large AC and backed up refrigeration. I don’t see that either function will help me in my situation. Am I overlooking or misunderstanding the manuals?
Thanks.. Joe
Thanks.. Joe
