That is tape, and I didn't put anything. What you see is how things showed up.Is that tape on those holes? Did you put that on there or did they come like that?
Who's we? You work at a rail yard? That's about what I figured though. Some process along the way where when an item comes out it goes into final shipper's hands. It wouldn't make any sense to parse a container at a yard. Probably wouldn't even be allowable for a 3rd party.We dont sort at rail yard. But that is where the customs house is.
Chain is .
Boat from china
In la port
Off boat onto trailer chassis.
Trailer chasis goes to customs house.
Leaves customs for either shipping company freight yard or...
Onto tran to next distribution hub
Chicago , Atlanta, rtc
I think it's safe to say we all paid for new grade A cells.
Yes. BnsfWho's we? You work at a rail yard? That's about what I figured though. Some process along the way where when an item comes out it goes into final shipper's hands. It wouldn't make any sense to parse a container at a yard. Probably wouldn't even be allowable for a 3rd party.
To me that's proof that the cells were shipped damaged. If you didn't put tape on those, somebody else knew there was a big hole in your cell and taped it.That is tape, and I didn't put anything. What you see is how things showed up.
I'm not sure whats behind the Kapton tape (if thats what it is). Haven't tried pilling it off. But the supplier definitely didn't give two shits about this shipment...To me that's proof that the cells were shipped damaged. If you didn't put tape on those, somebody else knew there was a big hole in your cell and taped it.
Or upsTo me that's proof that the cells were shipped damaged. If you didn't put tape on those, somebody else knew there was a big hole in your cell and taped it.
Or ups
I'm 30 minutes from king speed and even closer to ups distribution.I would tend to agree with you, but I live 4 hours from Chino, CA (KingSpeed) and, assuming they are being sent back due to shipper request because of wide spread damage to every order that was sent out, it would be difficult for them to have been damaged on the short couple of hops they would have had to make to get to me.
I think that what probably happened is that they were boxed and palleted in China, containerized, then pallets were broken down by KingSpeed and proxied to UPS.
Of course they were shipped damaged. Look at the shorted studs. If they shorted in the box, there would be evidence of that....burned cardboard, foam, or another cell having damage.To me that's proof that the cells were shipped damaged. If you didn't put tape on those, somebody else knew there was a big hole in your cell and taped it.
I highly doubt they would tape the actual cell of an unlabeled lithium battery inside of a box, then deliver it. Especially considering that they didn't use that black tape anywhere on the massive holes on the OUTSIDE of the box. I think that is the smoking gun.Or ups
Where are you seeing that? I see a taped up box and one battery with something stuck to it, but it does not look like tapeI highly doubt they would tape the actual cell of an unlabeled lithium battery inside of a box, then deliver it.
I specifically asked if the CATL 271 cells would be New Grade A cells, and was told they would be.I don't remember being told grade when switching to the CATL cells from Lishen...
post 393, pieces of black tape on the side toward the top of the battery, same cell with broken off post. The cell also has a lot of side damage....like it spent the day being dragged through the streets of town.Where are you seeing that? I see a taped up box and one battery with something stuck to it, but it does not look like tape
In @erarnund 's post on the last page. There is some black tape stuck to literal holes on the cell. He said that they came like that.Where are you seeing that? I see a taped up box and one battery with something stuck to it, but it does not look like tape
@Michael B CaroI believe the supplier is going to take care of this situation but not sure yet if that will be via refund or replacements.
I will be messaging everyone that bought has an order that I placed with that supplier as they want a specific number of cells involved.
I am still trying to get them to commit to just what the resolution will be before giving them that number but I want to start compiling it.
dittoI specifically asked if the CATL 271 cells would be New Grade A cells, and was told they would be.
