nhanus09
- May 27, 2022
- 66
Up2u.. I personally like to charge to 60% SOC then put them under compression at that point that way they aren't bulged then u can top them off under compression. This is also how Jay from Jay build cool stuff does it and I think it's not a bad idea.. how are you building your enclosure..That's a lot. I have only 16. From what I understand. 50% soc if good for long term storage. I'm planning on putting it together asap. I'm going to top balance them before assembly. Should I drain them to 3.29 and then top balance?!?
I would still like to see what is the average resting voltage will be between cells.
Also I got this gizmo from Amazon. for discharge. It's tops at about 19a and takes 16h. But still helps. I can also monitor IR it creaps up as it the cell drains. It hits 0021 at about 3.29v
I'm first going to build a cpl 12v packs using the SFK kit case for a few ppl. I'll probably only keep 16 for my future 48v system
