Hi, I'm in the process of converting a van for long term travel (at least 1 year). I don't know if I'll be adding solar right away but have some questions about "fast charging" via the alternator/smart battery isolator. Any feedback is welcomed and appreciated.
- I've estimated apx. 150 amp hours per day use at max
- Looking at Renogy AGM/Lithium or Battle Born lithium
- Will charging via the alternator be detrimental to the battery?
- How long might it take to charge from the alternator?
100Ah 12V LiFePO4 Deep Cycle Battery
The 100Ah 12V LiFePO4 Deep Cycle battery is the pinnacle of battery technology and the lightweight drop-in replacement for lead acid batteries.
battlebornbatteries.com
12V 200Ah Pro Smart Lithium Iron Phosphate Battery w/Bluetooth & Self-heating Function
Renogy provides solar panels, charge controllers, inverters, lithium batteries, portable solar generators and other equipments for off grid solar power systems
www.renogy.com
Deep Cycle AGM Battery 12 Volt 200Ah
Renogy's 12v AGM Battery will keep you going for as long as you need. Never be without power agian.
www.renogy.com
