filippomasoni
I found different fuse holders, some are really cheap like this one https://uk.rs-online.com/web/p/fuse-holders/7652942 and some are 10 times as much. Maybe because the 160A is thinner and when going up they need more copper. But I'm not really sure how to check for compatibility. It's industrial stuff and not very user-friendly, even the spec sheets have so much info it gets confusing. I was thinking of connecting it with it resting of the end of a copper bar and bolting a piece of copper on top so that the copper squeezes onto those fuse terminals. Once tighten it should have a good connection, but it's definitely too much of a hack and not worth the hustle and risk, so not going to use NH. The one I linked (only about 10 euro) is rated for DC with a breaking capacity of 25kA, which is on par if not more than blue seas T class.Be careful with that. NH is used a lot in industry and distribution cabinets, they need a special carrier that's bulky and not cheap (but real good). Also, the NH rated for DC and currents available on battery packs is extremely expensive - few hundred Euros per fuse.
HRC is good for solar lines and they have a nice carrier to them.
I believe the class t is the most suitable for our cells and smallest/cheapest option, even if you need to import them from US.
Recently I've ordered a couple Bussmann LMT fuses from eBay but didn't received them yet. They are the only alternative to class t I've found in Europe.
Anyway, the other one I found, from another supplier, the same kind of industrial seller, is the Bussman BS88 180A LET series. From what I understand the LET series has a capacity from 25 to 180A and the LMT from 160-450A but should be of the same quality. It's about 20 euros and I might try that, 180A is enough for my system as I'm never going to go above 150A.
